C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Dyno Differences
Old Feb 16, 2006 | 10:54 PM
Cscokd's Avatar
Cscokd
Default Dyno Differences
Does anybody know if you run on a Dynapack dyno if it's basically the same horsepower and torque numbers as a Dynajet or Mustang dyno? Is there a correction factor commonly used? Just my curiousity because I sometimes hear folks say corrected rwhp, etc.
Old Feb 17, 2006 | 09:38 AM
y2kcorvettebob's Avatar
y2kcorvettebob
iS THAT COMING FROM FOLKS WHO HAVE NOT ACCEPTED THEIR HORSEPOWER of lack thereof??
My car is 368 RWHP but corrected it's 550
Old Feb 17, 2006 | 10:12 AM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
I know that there is a difference in the numbers, from what I've seen so far, the Dynapak reads 5-7% higher.
For example: two cars that dyno'd ~ 650 RWHP on our DynoJet gained 50 RWHP on a Dynapak.
Old Feb 17, 2006 | 11:32 AM
Synergy Motorsports's Avatar
0Synergy Motorsports
Former Vendor
Not true. The problem is the Dynojet is the one thats inconsistant with numbers. Tires, gears, all the little things effect the numbers. The dynapack is not effected by those things. Look at Oz's car. It did just under 600 here and just under 600 on your dyno as well. I had guys from local dyno jets come over and get 10hp less. Happens all the time.
Rick
Old Feb 17, 2006 | 05:24 PM
#001 2001 Z06's Avatar
#001 2001 Z06
NCM, WSCC & SCC Member
Rick
I know of four other cars that have dynoed equal or more than Rick's dyno on a dynojet. Some even support another shop with a dynojet. lol. Perhaps we should have them come on here.
Here is one. Mine dynoed more on a dynojet before I met Rick and had it tested on his dynopak.
Not mention that the other car, that was mentioned earlier had a broken in new rebuilt clutch in it, because the old one, when it previously tested was dead and slipping. I guess it must have slipped your mind. Also his meth kit was working this time.
Old Feb 18, 2006 | 07:02 AM
ATI Performance's Avatar
0ATI Performance
Former Vendor
Inertia dynos give you a rough idea of your power, but are never consistent. They are cheap (for a dyno) which is why many shops buy them. All they can do is flat out power runs, and base their measurement on the acceleration of the drum mass, not true torque measurement.
Eddy-current dynos (i.e. Mustang) absorb power magnetically (and turn it into heat), and can be used to measure torque/power at steady speeds and are much more accurate and consistent. This is the only way to do tuning/mapping.
Well not really, there are also AC-drive dynos that OEM's use for development (i.e. AVL, Burke Porter) that can absorb AND provide power, and can hold vehicle speed extremely accurately under all conditions....be prepared to spend 7 figures. You will not likely find one in a performance shop.
Bob K
ATI Performance Engineering
To Dyno Differences
