Still unclear, what can I use at the track to datalog my run?
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Perfect, thanks. Sounds good, I've been drinking, ooops... Actually, yes, since I don't have a laptop the black box deal would work perfect. I was gonna pick up a cheap laptop off Fleabay just for this purpose but if I don't have to that would make the cost much more attractive.
Since both packages are good and although the blackbox seems to be a preference for you... IMO, what you should base your decision on is what your tuner is familiar with, people who are accessible to you or your vette buddies are using. It's alot easier to pick this stuff up... and there's alot to pick up.. when you have a bud w/ the same software.
If they're happy with what they have then so will you be..
Arnel
Arnel
1 Post
Cruise-In II Veteran
Makes since, but, if I'm gonna spend $540 for the scanning stuff I might as well drop the other $150 for the full package. So let's see, I need a laptop, EFILive, roll cage, harness, extinguisher, fire suit, new helmet after this year....
Don't mean to Hi-jack this thread, but it seems on-topic with my question.
Over the last two events last year and 3 events this year, my car has been displaying Check engine lights (intermittently -- on-off-on-off etc.) but no codes. The ocurr after the 2 to 3rd shift (MN6) The power drops during the these lights. On the street the car drives perfect, seems to be at about 5000 RPM's like injectors, spark, knock retard etc, but I thought each of those would set a code. I was thinking the same thing... can I monitor the systems in real time while the event is occurring.
I have an appointment this week to take the car back to the tuner, but even he says you need to be there when the light is occurring. He will re-check the tune (were any error codes shut off), look at what he can, and possibly put back the stock tune for a test session.
I don't have the Wide Band sensors so I guess all I could monitor would be the internal PCM data.
Now what was my point?....Oh yeah, first off anyone have any similar experience, or is there a more cost effective way to monitor the internal PCM activities. Again sorry for the Hi-Jack, but this is really getting frustrating
Ed
Ed
1 Post
motown, your flashing CEL may just be telling you it's misfiring. It may or may not be enough to set a code. A scanner can be very useful in determining what's going on, particularly when something's not right but codes are not set. If it's reproducible it should be easy enough to track down.
Originally Posted by ToplessTexan
It does add up, doesn't it? Don't forget the ice chest and lawn chairs. I guess you could always just wax.
Originally Posted by mdhmi
No point in logging if you aren't going to do anything with the data (meaning tweak it).
Mark
Mark
