C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Shift Time vs Shift Pressure
Old May 25, 2006 | 03:55 PM
jgorss's Avatar
jgorss
Default Shift Time vs Shift Pressure
I just purchase a Predator tuner and I’m a little confused, can some please explain the difference between Shift Time and Shift Pressure. From reading the description in the users manual it would seam that both adjustment do the same thing, change the firmness of the shift. Thank for the help
Old May 25, 2006 | 10:35 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
You're right... to a certain extent, the functions overlap. Shift Time adjusts the time it takes to change from one gear to another. It changes the speed of gear change and the amount of rpm drop between shifts. Shift Pressure is what adjusts the firmness.
HTH!
