C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Speed Density MAF Question???
Old Oct 2, 2006 | 08:23 PM
SCannon's Avatar
SCannon
Which is better for drivability MAF or Speed Density?
Old Oct 2, 2006 | 11:28 PM
Russ K's Avatar
Russ K
With a stock/mild camshaft a MAF or SD tune works well. But once the cam gets over 228 @ .050 the SD tune will be more responsive at low rpm.
And on the F-Body cars, the 78mm maf will be an airflow restriction on a wilder engine.
Russ Kemp
