C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Speed Density MAF Question???
Old Sep 23, 2006 | 08:00 PM
SCannon's Avatar
SCannon
Default Speed Density MAF Question???
My 01 C5 was tunes in speed density. When I unplug the MAF the car dies as soon as I touch the throttle. If I leave it plugged in and remove the air bridge so I can see the throttle plate, it is the same. I thought a speed density tune allowed you to not need the MAF?
Old Sep 23, 2006 | 08:31 PM
foff667's Avatar
0foff667
Former Vendor
yeah, doesnt sound like a SD tune to me
Old Sep 23, 2006 | 10:23 PM
DragMan's Avatar
DragMan
Cruise-In VII Veteran
Old Sep 23, 2006 | 11:15 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
True, but 2001 was the year they switched to integrating the IAT sensor into the MAF. You can run w/o the MAF, but not w/o the IAT sensor.
Old Sep 24, 2006 | 12:17 AM
foff667's Avatar
0foff667
Former Vendor
I would think that the iat would just go to a default # but the car would still run? I've personally never tuned a car/truck with the integrated IAT/MAF so im not sure, but yes very good point none the less.
Old Sep 24, 2006 | 11:27 AM
SCannon's Avatar
SCannon
I have run a 99 Tahoe and a 93 Z28 without the AIT sensors as a test and they still ran fine.
Old Sep 24, 2006 | 01:56 PM
SCannon's Avatar
SCannon
Here is my tune
www.hotrodz.org/vette/files/tune
Old Sep 24, 2006 | 04:56 PM
vetpet's Avatar
vetpet
Speed Density Tuning means you should be using the commanded fuel when in open loop table as the basis for fueling as opposed to the MAF sensor readings. If your car was tuned this way then the MAF sensor should have been disabled but the harness should not be disconnected as the IAT sensor is part of it (5 pins). Disconnecting the harness removes the IAT parameter that is used for speed density calculations so your car will not run right.
Old Sep 24, 2006 | 05:40 PM
foff667's Avatar
0foff667
Former Vendor
FWI I viewed the tune & indeed it "looks" to be in SD mode so I dunno.
Old Sep 24, 2006 | 06:18 PM
SCannon's Avatar
SCannon
The only thing that got me is the MAF sensor Air Flow vs. Output Frequesncy is still there. Even without the AIT sensor plugged in that is not enough of a reason that the engine will not run once the throttle is touched.
Old Sep 24, 2006 | 08:37 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
He knows his stuff
Old Sep 25, 2006 | 10:00 PM
Slowhawk's Avatar
0Slowhawk
Former Vendor
On a Vette,unplugging the IAT can really screw up how the car runs.Puts it into **** mode .(unlike a F-body).
I found this out a few days ago:o
Old Sep 26, 2006 | 01:16 AM
Russ K's Avatar
Russ K
On my 2001 ZO6 cam/header car, I removed the MAF and installed a 3.5" muffler tubing that I expanded to match the stock 85mmMAF.Then I
installed an IAT sensor, wiring pigtail and a grommet from a 2000 Corvette.
If you want to keep the MAF, then just set the MAF fail freq to 0 hz.
Russ Kemp
Old Sep 26, 2006 | 09:46 AM
foff667's Avatar
0foff667
Former Vendor
btw guys...i took a second look at his tune and it appears as if they set his maf codes to "no error reported" meaning if he removes the maf the computer will think the maf is still there & working fine...so the problem was it wasnt in SD mode after all.
Old Sep 26, 2006 | 09:47 AM
foff667's Avatar
0foff667
Former Vendor
Russ Kemp
it was set to 0 but they didnt setup the codes correctly so it was confusing the s out of the computer.
Old Sep 26, 2006 | 01:08 PM
Russ K's Avatar
Russ K
If the MAF fail freq is set to 0 hz, then code P0103 has to be set to no mil light. If set to no error reported, the the car will start & stall.
Russ Kemp
Old Sep 26, 2006 | 07:41 PM
SCannon's Avatar
SCannon
In tunercat the only options I have are ---No Error Reporting (type X), No Mil (Type C), Mil on 2nd Error (type C), and Mil on 1st error (type A)
Im an still unsure what to do here.
To Speed Density MAF Question???
Old Sep 26, 2006 | 08:04 PM
foff667's Avatar
0foff667
Former Vendor
turn the ses on & set it to either mil on 1st, mil on 2nd or no mil...the only 1 you CANT do is no error reported & thats what they did lol
Old Sep 27, 2006 | 10:17 AM
Russ K's Avatar
Russ K
I'd say your car was maybe tuned SD, then the maf was re-enabled after.
And the P103 was set to no error reported (type X) Check code P0102 for being set to no error reported as well.
Russ Kemp
Old Sep 27, 2006 | 05:27 PM
SCannon's Avatar
SCannon
All 3 are set to NO Mil P0101, P0102, and P0103, MAF fail frequency is set to 1,
