C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Tune?
Old Dec 16, 2006 | 09:45 PM
harleycontracter's Avatar
harleycontracter
Default Tune?
Changed to Granitelli air system,Bullet exhaust,Magnaflow x pipe otherwise mechanically stock. Would a tune do anything??
Old Dec 17, 2006 | 07:25 AM
see5's Avatar
see5
As long as the Granitelli is not their MAF, probably not much.
Old Dec 18, 2006 | 11:52 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
shoot Slowhawk a pm
Old Dec 19, 2006 | 01:59 PM
Slowhawk's Avatar
0Slowhawk
Former Vendor
I agree. The MAF should be tossed.
Old Dec 30, 2006 | 03:36 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Do you mean the Granatelli twin-flow air box ??? I have one of those--they work very well--as the others said the granatelli MAF--toss it and put the stock one back on--I have found that the corvettes are already pretty finely tuned from the factory and the most I've gotten is about 10-17 RWHP with a tune--With the air box and exhaust it will help to get the fuel trims back closer to "0" as all that stuff has a tendency to lean it out--The ECM will be adding fuell at PT so when you go to WOT--it will be a locked positive in PE which is not what you want--but all this stuff isn't so bad that it will throw codes just not be as smooth--If you have an A4 then I would deff get a tune to work on the Trans. settings--alot of performance is hidden in there especially with the TQ mgmt.,shift times--shift at VSS and sihft at rpm--TCC lockup--base pressure,abuse mgmt,
To Tune?
