C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
18 Degree overlap - surging
Old Jan 10, 2007 | 01:24 PM
WKMCD's Avatar
WKMCD
Default 18 Degree overlap - surging
I'm running a cam with 18 degrees of overlap on a 110 lsa and I have some surging between 1500 and 2000 RPM. Is it realistic to expect that an SD tune can get rid of this?
Other than this area the car idles well and runs very strong.
BTW: This is a 402 w' 12:1SCR 8.8:1 DCR with L92 heads
Old Jan 10, 2007 | 05:25 PM
Slowhawk's Avatar
0Slowhawk
Former Vendor
SD tune should get rid of it.
Old Feb 10, 2007 | 05:18 PM
ThePatriot's Avatar
ThePatriot
I've been having the same problem with my cam profile (.570/.570 @ 239 Intake / 251 Exhaust @ 8 Degrees Separation). There were several hits in the forum concerning an air leak between the MAF and Throttle Body. I did find a trouble area on my Carbon Fiber bridge and working on it helped a little bit but still can't cruise at 60mph. It starts getting tempermental around 55 and is bad through 63. I'd be interested in any lessons you learn here. I've got LS1 Edit and a Predator but not particularly good with LS1 and their support sucks royaly.
Good Luck!
Old Feb 14, 2007 | 08:02 PM
Jake@EPP's Avatar
0Jake@EPP
Former Vendor
If you have EFI-Live, then do a Auto-ve for the part throttle stuff, usualy takes the gremlins out of it. There is also timing to consider.
Old Feb 16, 2007 | 08:52 AM
ThePatriot's Avatar
ThePatriot
Well, unfortunately for me I only have a Predator and LS1-Edit. I haven't had much luck there. EFILive sounds pretty interesting but I'm spent on tuning software. Thanks for the feedback, though.
Old Feb 16, 2007 | 10:46 AM
foff667's Avatar
0foff667
Former Vendor
SD/VE tuning is always much easier when you have a good scanner.
Old Feb 16, 2007 | 11:24 AM
WKMCD's Avatar
WKMCD
My current cam actually has 19 degrees of overlap. Several very good tuners have worked on it and it's gotten better but still not acceptable for how I want to use the car.
Plan B: New cam = 13 degrees of overlap installed with CNC'd Stage 2 L92 heads to replace the current stock L92 heads. We're also dropping the compression from 12:1 to 11.5:1 so we can run a little more timing up top.
Old Feb 16, 2007 | 04:34 PM
redhardsupra's Avatar
redhardsupra
surging is overfueling. overfueling will happen when you haven't tuned VE table correctly, or your injector information/flow is wrong. MAF should take care of it, but the moment you change the airpath, the MAF calibration changes as well and if not accounted for properly, ends up giving you wrong data, forcing the computer to miscalculate every single fuel decision.
what you're describing here is a pure example of bad tuning.
i've tuned idle on a Trex and MS4 over email and was able to get better results than cars that i've seen gone through _three_ different 'reputable' tuners. it's not easy, but it's doable, most pros just dont take the time, because it takes way too much time to get it done right.
Old Feb 17, 2007 | 06:14 AM
WKMCD's Avatar
WKMCD
The cars idles perfectly with the current 110lsa cam. It's the low/very slight throttle driving that's the problem. I get a "fluttering" in that area.
Redhardsupra, I've read your tuning posts on the other forum and I know you've done some incredible tuning. I wish you were closer.
Old Feb 17, 2007 | 10:50 AM
redhardsupra
mail me some logs and i'll tell you what's wrong. overfuling can happen anywhere, not just idle, idle is just the most popular area for it as that's where big cams are least efficient, that's all.
To 18 Degree overlap - surging
