Hp tuners, is that a good tune.
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,086 Likes
well said, HP tuners or EFI live are just tuning tools, the deciding factor is who is typing the key board. It's not like a hand held that just down loads a basic tune.
Received 1,762 Likes
HP Tuners is just a software package used for tuning.
The quality of the tune will depend on the person using the software.
Its like asking, is a z06 good for autoX. Of course the answer is...depends on who is behind the wheel.
Sorry I think I need a translater for what you are "trying" to say. You said a specific tuning software was the only way to go...that is what I was asking "why" about. Why is HP Tuners the only way to go?
is a wideband necessary to tune these when not on a dyno for a/f readings?....Ive been borderline EFI live/HPtuners wish i knew which one was easier to tune with and which one was more capable
Yes, you need a w/b. Without one you're just guessing on the AFR at WOT. If you guess wrong, BOOM. $200 for a w/b vs. $xxxx for a new engine. Not a hard decision. Either EFI or HPT is a good choice. I use HPT.
where you guys putting these widebands in your car and where are they getting the readings from....one of the rear bungs not being used or do you need one on each pipe so its getting readings from both banks?.....sorry tuning retarded here
Former Vendor
For a Na car you do not need a wideband to tune the car IF you know what your doing.If your a first time tuner then yes you should have a wideband.Of course it might be alot cheaper just to pay a tuner to do your car instead.
then it gets expensive when i tune after headers and CA....then a tune after a cam...then after heads...then after the 92/92 combo...tuners charge an arm and a leg to do it
most give you break on price, after the first tune, the first tune is what cost them money, becuase they have to register your vin #
I have used both HP tuners and EFI live, there are good thing and bad things about both. I think HP tuners is easier to use but I like some of the scanning that EFI live has.
If the truth was known, a-lot have just coping some one,s tune and hitting you up for 400.00 are more. If it is not a really known shop I wouldnt do it any more. will cost you more in the long run...
