C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Can this be tuned
Old Sep 18, 2008 | 05:20 PM
03blackZ06's Avatar
03blackZ06
Default Can this be tuned
I bought a fast 90/90 set up for my 03 procharged and cammed z06 with full exhaust. And the throttle body plate has a hole drilled into it. Can the car still be tuned with this? Or do i need to buy a new plate or even t/b? Thanks mike
Old Sep 18, 2008 | 05:28 PM
tjwong's Avatar
tjwong
No problem.
Old Sep 19, 2008 | 10:22 AM
intoc6s's Avatar
intoc6s
Can t u put a plug or bolt on/in the hole? It can be fixed. Do u mean the throttle "blade"? That can too.
Old Sep 19, 2008 | 11:58 AM
mowton's Avatar
mowton
Fill with a pop rivet. Find one closest to the hole in the TB or open the hole to fit the rivet....works like a charm. If you don't have to open the hole, can actually be done on the car. Will change the base air flow (RAF) substantially as well as the IAC setting if you have one.
To Can this be tuned
