C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
codes
Old Aug 24, 2009 | 02:39 PM
plm9's Avatar
plm9
Cruising
Default codes
I am getting pcm 1571, and tcs 1277. My traction control light is on, and i says service active handeling. Can anybody help
Old Aug 25, 2009 | 01:17 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
These type codes are quite often false triggered--often will set when going over railroad tracks or on a bumpy road---if the car seems to act and drive fine--i would just clear them and see if they come back---
The reason for the false trigger is the wheel speed sensors (which are used by the TCS system) will break contact or they will lose ground----
Even if the codes come back--check all 4 of the wheel sensors--make sure the pigtails are clean and the wires are not frayed-make sure there is no debris in the sensor area by the rotor --rarely do the sensors themselves need replacing--
