C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Afr
Old Dec 5, 2010 | 07:09 AM
XSPOWER's Avatar
XSPOWER
Default Afr
What AFR are you seeing at 1500rpm cruise on flat level ground?
Old Dec 5, 2010 | 10:14 AM
06MonteSS's Avatar
06MonteSS
Supporting Vendor
you'd be at part-throttle (closed loop), so your AFR will always be around 14.7... which is the stoich value that it should be at...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS LS3, short-throw shifter, NPP perf. exhaust, BMR strut-tower brace, Cold Air Inductions cold air intake, catch-can, ported/polished TB, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Dec 5, 2010 | 05:11 PM
XSPOWER's Avatar
XSPOWER
At just enough throttle to maintain speed I'm seeing 20.0. At WOT the least I see is 11.9
Old Dec 5, 2010 | 06:05 PM
06MonteSS's Avatar
06MonteSS
Supporting Vendor
20??!!
your AFR is at 20??? or is it your fuel trims that are at 20??
Old Dec 5, 2010 | 08:00 PM
XSPOWER's Avatar
XSPOWER
My wideband is showing 20
Old Dec 6, 2010 | 02:06 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
11.9 in power enrichment or WOT is the stock programmed AFR--Its pig rich that way from the factory---tuning will add some HP by leaning it down some--On a DD car i normally set it at a safe 12.4-12.5 on a more performance level you can go like a 12.7-12.8 and on a race only application maybe 12.9-13.0
20.0 in "closed loop" or during P/T has to be an error--the stoich value as mentioned should be 14.7 so if it is in indeed 20.0--it is parts breaking lean---i wouldn't drive it that way--
If you have a LM1 wideband---the callibrating AFR when the unit is turned on before starting is 20.90 maybe somehow this value is stuck in your waideband an it's not reading correctly--try re-calibrating the unit
Do you have any mods ?? have LT headers ???
Old Dec 6, 2010 | 05:35 PM
TT Z06's Avatar
TT Z06
Sooo many other thinks to factor in. Loaded or unloaded? what vac? altitude? what gear? engine mods?............and the list gos on
Old Dec 6, 2010 | 05:42 PM
XSPOWER's Avatar
XSPOWER
Mods are heads,cam,intake,exhaust, bigger injectors, fuel rails, and a boostapump. I'm running a NOS launcher with a wideband O2 to monitor and shut down in case of a lean condition. This particular setup isn't able to calibrate as far as I can tell. There is no cal. procedure in the install doc anyway. I think I will take it to a friend that is a tuner and has a Mustang dyno and have him hook up his wide band to compare. Never the less I'm not sprayin till I get this figured out
Old Dec 7, 2010 | 07:13 PM
Corvette Don's Avatar
Corvette Don
What wideband do you have? Does it go to 20 then settle down to ~14.7?
Old Dec 7, 2010 | 08:14 PM
YeloFevr's Avatar
YeloFevr
My gauge says 'WTF' at anything over 18.
Old Dec 10, 2010 | 10:49 PM
chevy406's Avatar
chevy406
There are ways to force the ECM into open loop at specific rpm ranges. Some tuners like to keep the computer in open loop at idle through 1200 rpm. There is no good reason for you to see a steady 20 AFR at low rpm cruise. That tune needs to be addressed. Hope your tuner knows all the values for the specific injectors you are using. It makes a big difference in idle and low rpm performance.
Old Jan 8, 2011 | 01:48 PM
tblu92's Avatar
tblu92
ALSO---trying to get an accurate AFR at 1500 RPM is pretty tough anyway---Thw wideband tends to bounce around all over the place---Another thing to consider is that when "lifting" the DFCO system becomes active (decel fuel cut-off) when active the ECM shuts the fuel OFF and the wideband will show it's max AFR cause there is NO fuel present- P/T AFR tuning can't be done on a dyno anyway--has to be under normal street driving-- and the fuel should always be trying to correct itself automatically to 14.70 with data rec from your front 02's via your fuel trims-----
To Afr
