C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Check Engine Light
Old Jun 30, 2011 | 11:11 AM
Fundo's Avatar
Fundo
Default Check Engine Light
Had a check engine light on my '99. Took it to the dealer, bad air pump. Had air pump replaced--technician said it threw another code-valve hung up, which apparently is tied into the air pump fault code. Flow chart said drive few miles and it would reset. Technician drove it and the code cleared. I picked it up and within 3 miles the light came back on. Any ides as to what would cause this? Car seems to run OK, but I'm worried about driving it with another check engine light. I hate to keep driving it this way.
Old Jun 30, 2011 | 07:30 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Need the exact code---you can do a search on the forum on how to pull the codes yourself---or borrow a scanner from someone or have your shop read them for you
I don't know of a "bad air pump" code----
If they replaced the pump and you are still getting some codes--the most common codes are for the secondary air check valves
including: P0410-----P0412----P0418------P1415----P1416
Old Jul 5, 2011 | 01:05 PM
Cliff Meima's Avatar
Cliff Meima
2nd Gear
Default P1416 help please
tblu92
my 2001 is posting P1416 every few days, do you suggest pulling the secondary air valve out and cleaning it? BTW this is the first code I have had bought the car new in 2001.
Cliff
Old Jul 5, 2011 | 01:07 PM
Cliff Meima
2nd Gear
tblu92
Cliff
Old Jul 6, 2011 | 11:38 AM
tblu92's Avatar
tblu92
OK P1416 is for the right side air check valve--You can try to clean it out with brakeclean and re-install--I think that valve is somewhere behind the engine and has some weird routing going on--
2nd i would replace the valve if the codes come back--
Those AIR codes are pesky--as miles add up they just seem to pop up for no reason and you may have to chase them forever--On my 98 i finally just turned OFF all the AIR related code enablers and was done with it !!!
Must have EFILIVE or HP or something silmilar to turn codes permanently off---These cars run so clean smog isn't affectd much even if you removed the entire AIR system--The pump only runs breifly at start up (maybe 5-10 seconds) to help light off the cats--sometimes not at all--
Old Aug 28, 2012 | 08:52 PM
cadmando18's Avatar
cadmando18
Default Question about deleting these air pump codes for good
My 2001 Corvette is also throwing a code, P0410. I just bought the car and now it's back at the dealership. After reading up, sounds like my best bet is to let them try and fix it as it's not going to cost me anything. Oregon law, they have to get the car to DEQ I guess.
At any rate, my question is more for down the road, if I wanted to program out these codes all together. If I do this, and I need to DEQ it down the road, will these deleted codes cause the car to fail DEQ? In Oregon they just plug the car in and check for codes.
Thank you!
Old Aug 31, 2012 | 08:10 PM
plumberh2o's Avatar
plumberh2o
Default codes ?
Got a code of 10 pcm and 40 bcm anyone know what they stand for?
cleared codes and the light has not come back on but i have not drove to long.
Thanks for help.
Ken
To Check Engine Light
