C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
C5 Z06 P1120 Throttle sensor code
Old Sep 26, 2011 | 07:33 PM
Vettdaddy's Avatar
Vettdaddy
Default C5 Z06 P1120 Throttle sensor code
Have read lots of posts, still need some clarification. It is running crazy now, sometimes starts and runs about 2000 rpm in reduced power mode, no pedal input to speak off. Sometimes it starts and quit again right away.
P1120 code appears every time I clear it, dash has reduced power, traction controll, low tire lights.
I pulled the plugs off TP sensor, was oil wet from an incident where engine installer did not tighten the power steering line to the pump.
I cleaned well and dried it out and it, check voltages on pin seem ok and consistent, did same on throttle side.
Question, I can move the throttle butterfly easy with key off, key on it stays closed and I cannot move it manually, or with the pedal, is this normal? It is in reduced power mode right now.
Torx bolts have the anti theft pin, so cannot get it off with normal torx tool, is this a GM factory thing?
This already cost me 500 bucks at the expert shop, not sure if they had this code or not. This car's dyno run was 515, has a bunch of goodies and about 12.5 compression.
REP on most of the time, traction control, abs on dash too.
Driving me nuts, any comments would be appreciated, thanks. CK
Old Sep 27, 2011 | 08:08 AM
Pro Street's Avatar
Pro Street
Post this over in the C5 Tech. You will get more help there!
Old Sep 28, 2011 | 10:39 AM
Vettdaddy's Avatar
Vettdaddy
Did the same post over there, no luck. Always seems when my cars have an issue, it never happened to any one else.
Looking for a local with a complete throttle body to test, Thanks CK.
Old Apr 22, 2012 | 12:53 PM
Vettdaddy's Avatar
Vettdaddy
Default Replace throttle position sensor
Fired right up, $138.00. Got oil wet when power steering hose came loose.
To C5 Z06 P1120 Throttle sensor code
