C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
external map sensor
Old Jan 13, 2012 | 11:52 AM
kj217's Avatar
kj217
Default external map sensor
anyone ever used an external map sensor instead of the stock one for SD tuning?
I got an external 2 bar map with alky meth kit and wondered if someone wired it to pcm,,
Old Jan 14, 2012 | 02:39 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
On the newer FAST manifold they have re-located theMAP sensor from the back of the manifold to the front---reason is that their is very little clearance next to the cowl and it wouldn't fit or it would break off---I've seen MAP relocation kits on the internet for this same situation--I belive the kit somes wih a pigtail extension---I would also think you would have no reason to rewire the MAP to the ECM--just use the existing pigtail--Is there another reason why you think you would need to re-pin the ECM ???
Old Jan 17, 2012 | 01:21 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Yes you can do that to answer your question. I've done it many times, but instead, I use a GM 2 or 3 bar sensor and tap the signal for the alky kit.
I would recommend that you remove the MAP sensor from the Alky kit and wire it into the factory wiring and then tap off the reference wire (should be green) to trigger your Alky system.
To external map sensor
