C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Idle problem, need help
Old Apr 15, 2012 | 07:21 AM
edkonda@encode.com's Avatar
edkonda@encode.com
6th Gear
Default Idle problem, need help
I have a new LS3 crate engine with stand-alone harness. It seems to me that when this engine is first started, it revs to 2000 rpm for 1-2 seconds then immediately drops to idle, around 850 rpm. This is quite good. Then when it gets hot, on a restart, it revs to 2000 but does not drop back to idle. What should I be looking for? Any ideas while I'm waiting for a scan tool?
Old Apr 16, 2012 | 12:22 PM
Zip Corvettes's Avatar
Zip Corvettes
Platinum Supporting Vendor
Your idle air is wrong.
Old Apr 30, 2012 | 12:43 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Typically it's the idle air control as mentioned--"desired airflow" in EFILIVE--It is scaled by coolant temerature---
Also remember that when the engine is 1st started either dead cold or warmed--The ECM is in "open loop" mode---when dead cold the coolant must reach apprx 140* before it changes to "closed loop" afrer warmed it switches to a timer-usually around 20 seconds before it will change into closed loop--- Many times especially with long tubes--the open loop fuel mustt be leaned down to avoid erroneous data and to get rid of start-up surging/dying/hanging
Old Apr 30, 2012 | 07:54 PM
Slowhawk's Avatar
0Slowhawk
Former Vendor
Could be a vacuum leak.
Old May 2, 2012 | 09:24 PM
Tampa Tuning's Avatar
0Tampa Tuning
Former Vendor
St. Jude Donor '12
Default Corvette Camaro GTO tuner in Tampa
do you still have the tune from the motor of a C5 in the car ?
To Idle problem, need help
