C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
AutoTap problem...
Old Jul 21, 2002 | 04:28 PM
ScreaminDemon's Avatar
ScreaminDemon
Default AutoTap problem...
I'm keep trying to connect and I'm getting code 57-7, loss of memory and to contact Autotap. Anybody know what this is? I've checked all connections dozens of times and it is the B&B chord (not my edit chord, which I've done alot). I have v1.03. Any help before I contact Autotap?? :confused: :confused:
[Modified by ScreaminDemon, 2:28 PM 7/21/2002]
[Modified by ScreaminDemon, 2:45 PM 7/21/2002]
Old Jul 21, 2002 | 06:18 PM
allanlaw's Avatar
allanlaw
Default Re: AutoTap problem... (ScreaminDemon)
I have v1.03.
That's a pretty old version, whether it's DOS or Windows. You sure?
Old Jul 21, 2002 | 09:18 PM
ScreaminDemon
Default Re: AutoTap problem... (allanlaw)
Yes, and I've only had it about 3 months. The CD says version 1.03. What is available now, and is a free upgrade?
Old Jul 22, 2002 | 01:20 AM
ScreaminDemon
OK, I'm downloading v2.02 right now, I hope that's all I need. But the housing on my cable feels loose.
Old Jul 23, 2002 | 03:02 AM
allanlaw's Avatar
allanlaw
The connection to the car feels loose on mine, too, but it's ok. The first thing is to make sure you follow the correct sequence on start-up - the ignition has to be on before you connect the cable to the car, and before you start up Atap.
Old Jul 28, 2002 | 03:32 PM
SANMAN1's Avatar
SANMAN1
My setup continually failed Friday until I removed my wireless card. It would never load correctly, ask for the VIN sometimes, and the readings were really whacked. I pulled the wireless card and everything was OK again. Some sort of conflict with the wireless drivers, I suppose
To AutoTap problem...
