Has ANYONE Ever Loaded A TTS Powerloader Over Ed Wright Programming???
1 Post
Cruise-In II Veteran
Re: Has ANYONE Ever Loaded A TTS Powerloader Over Ed Wright Programming??? (Buckmaster)
Presumably the worst case scenario is that you'd need to install a stock flash first (as if you were installing a factory fresh PCM.) That assumes any "locking" is self contained in the flash.
I thought this was discussed before? I think I remember babbling about flattening the stock sigmoidally shaped curves in the shift speed tables.
How about the second part of the question then? The "throttle angle" parameter for the A4?
1 Post
Is the stock sigmoidally/shift speed tables the same parameter as the throttle angle position?
I have never heard it referred to the words you use.
