Basic tune questions
I have all the stuff, wideband, HP Tuners etc.
When you pull an O2 to install a wide band just to read A/F do you turn it off in HP tuners?
My car is a cam only LS6 with LG headers and catless X pipe, Vararam and 11 to 1 compression.
I found a tune in the HP Tuners repository that should be very close and was going to copy it over and then run the wideband to see whats up.
TIA.
TIA.
Car will not use the O2 sensors at that point. You are also going to want to watch for the adders in openloop. Make sure there is no fueling being added while scanning. Open loop EQ ratio is one that will add fuel until car is up to temp for instance.
