I just bought a tech 2 and have read the manual a few times but there are a few things I am unclear on.
I got this to read the DTC's off my car. Programming at this point is beyond my scope.
so I connect it to the ALDL connector and I know it is making contact because it powers on using that connection
but when I try to get any information it tells me it cannot communicate with the vehicle
It asks if the key is on or off. I turn the key on and the screen goes blank and freezes
I am using the scan tool because my DIC stopped working so I cannot get any codes from that
If your Tech 2 is a “Chinese Clone" your scan tool would be suspect !!...try connecting another one if you can. I’m thinking of buying one as a backup to the one I have but will get a genuine one...probably over a grand for a used real deal one.
Thank you all for the responses. When I connected it the first time I was flipping through the different screens to see what it would do until finally the screen went blank. Then I noticed the battery had less than 10 volts. Bad weather today kept me from going out so I ll look at this tomorrow
f your Tech 2 is a “Chinese Clone your scan tool would be suspect !!...try connecting another one if you can. I’m thinking of buying one as a backup to the one I have but will get a genuine one...probably over a grand for a used real deal one
Jonnyc
I just want to be able to read and correct any DTC's I don't know enough to change a program or have a need to. I got that clone so it would read
the different Modules
Jonnyc
if it's possible i would return the tech2 and get the elm and torque app like i mentioned above.it will do everything you want and more and it is cheap.
I too bought a KONNWEI OBD2/EOBD scanner [ KW808 ] I also am getting somewhat the same thing. First of all I get a LINKIN ERROR, also get VEHICLE INFO [ NOT SUPPORTED ], 02 MONITOR TEST [ NOT SUPPORTED ], LIVE DATA [ LINKIN ERROR, also can not get the MIL STATUS to show on [ it is in OFF ] I have unplugged and plugged in several time the 16 pin cavity connector and each time turn ignition off wait 10 seconds. STILL nothing...……….I am thinking I have a bad one.
The Chinese ones are really hit or miss now that they've come way down in price. I got lucky on mine, but I know of a handful of people who have had issues. Contact the seller and see if they can make it right. Most of them are decent. ****, I got mine on Aliexpress and it was shipped from China to my door in 4 days.
I will agree that if all you care about is reading/clearing DTCs, you can't go wrong with Torque. The Tech2 is one of those tools you rarely actually need, but if you do need it, you NEED it.
