C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Spark Plugs......
Old Jan 28, 2019 | 09:58 AM
clutch1's Avatar
clutch1
Default Spark Plugs......
would like to go hotter ...The plugs I have now are, TR6NGK...After two years, they are turning black...My LS1 is making 493 HP...So i want to go to a better or hotter plug..?John.
Old Jan 29, 2019 | 04:32 PM
gimp's Avatar
gimp
You need to tell us about your setup.
Also, who tuned your setup? What do they recommend?
Old Jan 30, 2019 | 09:51 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Typically a TR6 is used on boosted applications and not needed on a N/A engine
The TR55 or TR5 is a better choice
There may be other reasons for the black plugs--usually means a over rich condition---
Without knowing your combination it can be many things that are the cause
1 too little timing
2 fuel trims way off during P/T
3 injector flow rate not properly scaled (if you installed larger ones)
4 dirty air filer OR fouled MAF sensor
5 incorrect fuel pressure
6 LT headers----( LT headers require special tuning as they always make your engine run RICH)
Lowering the 02 switching points helps--try to get your front 02 averages to be around .400 to .500 millivolts The larger the average reading the richer the P/T fueling becomes-- the re location of the front 02's as much as 3' back makes them not read correctly and gives your ECM false readings--That is why they are illegal in most states--
Old Jan 31, 2019 | 12:40 PM
96CollectorSport's Avatar
96CollectorSport
From: If you don't weigh in you don't wrestle Road America
Here are the NGK plugs from hottest to coolest (more hp you would want to run cooler)
TR5 – 2238 (.040)
TR55 – 3951(not colder just larger gap - .050)
TR6 – 4177 (.040)
BR7EF – 3346 (.030 gap)
RS5724-8 – 7317 (.030 gap)
RS5724-9 – 7891 (.030 gap)
RS5724-10 – 7993 (.030 gap)
From stock LS1 to LS3 the NGK website shows the TR55 as a standard replacement
The LS7 and LS9 they have the TR6 listed - so you already have a plug they feel is correct for 505 - 640 hp
As stated above tuning issues may have more to do with your spark plug color than plug selection
Old Jan 31, 2019 | 01:57 PM
clutch1's Avatar
clutch1
493, HP, 639 LIFT CAM..what gap on my TR6 plugs...? thanks John.
Old Feb 1, 2019 | 10:11 AM
96CollectorSport
.040 gap
Old Feb 2, 2019 | 01:10 AM
tblu92's Avatar
tblu92
You guys are all way to concerned about plug gaps-- Gm originally suggested a .060 gap on their stock LS engines then later they changed it to a .040
Plug gaps are not that important---however with a .040 there is less of a chance with old wires for the spark to not fire and go to ground instead
From a racing background with over 25 years of racing experience the most important choice is not the gap but the "heat range" There is no HP advantage by going to a colder/hotter plug unless when reading your plugs they show abnormalities--
The smaller gaps now recc by GM are strictly to avoid misfires from poor wires--or poor ignition voltage------
Old school reading of plugs still applies even in today's computer controller cars
Ideally with new plugs-----you would want the color change on the strap to be exactly on the bend---Closer to the threads would mean you have too much timing--closer to the tip means you need more timing As far as AFR goes on new plugs you want the color to be about 1/8 to 1/4 " above the bottom of the center porcelain
An in correct heat range would be indicated by both of these factors not being even close------A car driven on the street mostly at P/T needs a hotter plug to clean them out----A racing plug or a colder plug is only needed with a boosted engine or a highly modded N/A engine that rarely sees RPM's below 3500---
To Spark Plugs......
