Installed the program without any problems and took it out on a short test run. No SOPT performance gain . Too much detonation, I think it's running worse. I'm using (and have always used) 92-93 octane. This tank is from Texaco. I'll test drive it more later today, but at this point I'm a little discouraged. :cry
Hey friend, if you would like to give me a call we can discuss the issue you have having. Are you using 92 or 93? I'd also go for Shell 93 or Amoco 93 before Texaco. Which stations in your area carry 93, instead of 92?
I can go by the Texaco station today after work and let you know if it is 92 or 93. I have never seen an Amoco station in Ft. Worth and Shells are few and far between. I want you to know that I'm all for your product and I'm just giving an honest opinion. I will have an opportunity to drive the car some more later on today. I'll be happy to give you a call (perhaps tomorrow after more test driving) and provide you with any information I have. Thanks.
From: Admit Nothing, Deny Everything, Make Counter Accusations.
Re: My Predator Initial Report (BfB)
You know, you simply amaze me with how much *hidden* bashing you do of the Predator
Bashing? No.
Reality check time...
I said a few times that the Product has the potential to be very good if you tune the car on a dyno with a wideband and a good scanner. I also said it would be a better value than buying a MAFT/Fan controller/CAGS defeat and it would not require soldering and splicing. That does not seem like bashing to me.
Blind mail order "performance tuning" has never been a way to build significant HP. Changes to a state in tune that are signficant enough to cause a real change in HP need to be monitored on a dyno and with a good logging scan tool. This is nothing new, it should not come as a surprise to anyone, and it is not a bash directed at the product.
