C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
P0441 Code
Old May 17, 2019 | 08:56 AM
Turbo Bob's Avatar
Turbo Bob
Corvette Challenge Champ-01
Dragster Challenge Champ-06
Default P0441 Code
1998 Corvette coupe with auto trans. LS3 crate 376/525 engine. Keep getting a P0441 code small EVAP leak. Already replaced gas cap. Any help would be much appreciated. Thanks.
Old May 22, 2019 | 01:56 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Hey Bob !!...I looked for my '01 P0441 and none listed...I believe a 0441 for a 98 is a "Evap system no flow during purge"...the purge valve (pic shown) is NORMALLY closed...it is just 2 wires...power and a ground supplied by the PCM when it tests the system...if the PCM doesn't see the PCM pull the 12 volts to ground because of a wiring issue OR a bad purge valve the DTC will set...you can remove the connector and check the wiring visually (have you been messing around in that area ??)...I work at the airport and if you want I can bring my scan tool and swing by after work (I get out at 6:30 PM) and can operate the valve and also with a test light I can check if the PCM is supplying the ground...let me know !!...I'll recheck the DTC description for a '98 when I get home !!....you can check to see if you have 12 volts at the PINK wire which is the feed !!
Rob
Old May 22, 2019 | 03:42 PM
Turbo Bob's Avatar
Turbo Bob
Rob
Hey Rob. Appreciate the help. Think I may just buy a new purge valve and replace the old one if I can find one.
Old May 22, 2019 | 03:51 PM
C5 Diag's Avatar
C5 Diag
Ok !!...great !!...I’ll check the 0441 description when I get home...to remove the valve you have to squeeze together both tabs (pictured)
to release each of the plastic hoses...can be tricky !!
Old May 22, 2019 | 03:56 PM
Turbo Bob's Avatar
Turbo Bob
‘Got it. Thanks.
Old May 22, 2019 | 04:08 PM
Turbo Bob's Avatar
Turbo Bob
Hey Rob, This is a picture of my purge valve.
Old May 22, 2019 | 10:39 PM
C5 Diag's Avatar
C5 Diag
Thanks !!...a little different style wise by still operates the same way !!...like I said all you can do is check for power !!...good luck !!
Old May 26, 2025 | 10:33 PM
Darik7's Avatar
Darik7
2nd Gear
people keep saying this is your purge valve, but it isn't? Your purge valve plugs into this via black line.... did you ever find out what it is?
To P0441 Code
