C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Blower..........
Old Jun 10, 2019 | 10:28 AM
clutch1's Avatar
clutch1
Default Blower..........
Have a 99 corvette, LS1, not stock...What blower would you recommend? John............
Old Jun 11, 2019 | 06:18 PM
gimp's Avatar
gimp
What's your goal with the car?
Old Jun 12, 2019 | 04:47 PM
clutch1's Avatar
clutch1
more power..
Old Jun 18, 2019 | 04:37 PM
gimp's Avatar
gimp
If you have no specific goals beyond "more power" then literally any blower will give you more power. Buy the cheapest one from a reputable manufacturer and get their tune.
Old Jun 18, 2019 | 04:38 PM
clutch1's Avatar
clutch1
what do you think about the 8 rib procharger?
Old Jun 18, 2019 | 04:56 PM
gimp's Avatar
gimp
People seem to like their procharger setups. Centrifugal setups are pretty easy to install, route, and tune, and they tend to allow you to keep the stock hood. Their power delivery will be "peakier" than a positive displacement unit, but that might also help you hook up at low RPM compared to a positive displacement unit. Make sure whatever tensioner you use is up to the task, and I'd probably recommend you pin the crank pulley. If the crank pulley is original / stock, get the upgraded unit. Some people like underdrive units, probably a 10% underdrive won't lead you wrong, but I personally don't care much.
If this is for relatively mild street use, you should be pretty much set with that. If you're gonna run it hard, you're in for a lot of money in upgrading the rest of the system.
Old Jun 18, 2019 | 07:19 PM
aaronc7's Avatar
aaronc7
I recommend A&A with vortech blower. As far as 6 vs 8 rib etc.... all depends on how much you actually want to make. Going 8 rib is about $1000 extra up front but gives you the option of more power down the road, etc.
Seriously, Josh and Andy @ A@A are very helpful... give them a call and talk about your goals or desires and they will get you squared away and won't try to sell you crap you don't need.
edit: definitely don't get a underdrive pulley with SC... Overdrive quite possibly depending on goals.
Old Jun 21, 2019 | 11:30 AM
clutch1's Avatar
clutch1
Thank you Sir..........
Old Sep 15, 2019 | 09:55 PM
Toys4Life C5's Avatar
Toys4Life C5
St. Jude Donor '21
A&A was my pick a little over a year ago. Love it!
https://www.corvetteforum.com/forums...s4life-c5.html
To Blower..........
