C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
C5 PCM issues help please
Old Jun 11, 2025 | 08:01 AM
srx700pilot's Avatar
srx700pilot
Cruising
Default C5 PCM issues help please
I had my c5 quit last fall. Car eventually starts and runs, but most gauges are inop. Dealer diagnosed as pcm. Chevy dealer has had it for 2 months. I had my factory PCM professionally rebuilt/repaired. The dealer bricked that one. I provided them 3 more used pcm’s which they bricked all of them. Took it to another Chevy dealer yesterday that said they could program my new (used) pcm. They called 5 hours later and said GM no longer supports programming 98 corvettes. I’m worried they tried and bricked this pcm. Questions are, if GM says they don’t support programming, is there anyone that can guide me on getting it programmed? Also, I’ve just been buying the same part number PCM. My c5 is manual. Do I need a specific pcm or same part number will work? Thanks.
Old Jun 11, 2025 | 03:20 PM
KOZ's Avatar
KOZ
Find yourself a local dyno shop. An experienced tuner with Hp Tuners can take a Gen 3 ECM and have you car running in about an hour. It's not a difficult thing to do at all, typical dealership quacks.
Old Jun 11, 2025 | 03:54 PM
srx700pilot
Cruising
thank you. I found someone with hptu er that is willing to give it a try. Seems easy enough. I don’t understand why a Chevy dealer can’t get this done.
Old Jun 11, 2025 | 05:16 PM
NSFW's Avatar
NSFW
Are the PCMs getting bricked during programming, or is there something that's damaging them electrically when the PCM gets plugged in?
Upgrading to a later PCM sounds like a good idea, there are lots of ways to program those, including an open source project that I worked on (PCM Hammer), and they're plentiful.
Might as well upgrade to a 2004 PCM while you're at it, they cost only slightly more and they can be tuned for flex-fuel if you add a sensor.
I've never done the re-pinning myself but it's fairly common. Anyone know if the pins are interchangeable?
Old Jun 13, 2025 | 10:56 AM
feeder82's Avatar
feeder82
You can repin a 99 to a 01-04
https://www.corvetteforum.com/forums...m-success.html
Old Jun 13, 2025 | 01:07 PM
srx700pilot
Cruising
They finally admitted they were bricking them during programming and said if I brought just one more they were “90% sure they could do it”. I rebuilt my first one which they bricked. I sent it in again to be repaired and the pcm repair business said it was now not repairable.
Old Jun 13, 2025 | 07:53 PM
NSFW's Avatar
NSFW
Originally Posted by feeder82
That link describes an EBCM upgrade, not a PCM upgrade.
PCM upgrades are definitely a thing though, for C5s and Camaros. I haven't done it myself but I met a guy locally who did it, and I've seen a handful of threads from people who did it.
Old Jun 18, 2025 | 01:39 PM
feeder82's Avatar
feeder82
Oops sorry bout that
Old Jun 23, 2025 | 12:34 AM
Eleven Bravo's Avatar
Eleven Bravo
Call Intelligent Performance and they can set your car up with a P59 PCM, from 2004. Or provide you with an alternative if yours cannot be converted. I have a 2001 Z06 with a P59 PCM from them.
Harrisburg, SD
605-681-6787
Jeremy@intperform.com
To C5 PCM issues help please
