C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Check engine light flashes - does NOT set code??
Old Jun 24, 2003 | 06:24 PM
Bytes U's Avatar
Bytes U
Cruise-In II Veteran
Cruise-In III Veteran
Default Check engine light flashes - does NOT set code??
OK... I'm looking for a little help here. Car has had some motor work done and custom tuning done by a well respected tuner. All tuning is perfect except the check engine light flashes about every 10 mins then goes out but doesn't set any codes. Full exhaust with cats and the O2 sensors check OK. Real time captures, gm tech 2, autotap, and LS1 Edit reveals no problems or codes being set. All tables well within spec etc. They even tried a brand new PCM... same flashing light but no code problems. Any idea's people? They are guessing it might be a resistance variable in the wiring harness but no-one really knows. Any theories guys?
Old Jul 2, 2003 | 01:39 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In IV Veteran
Default Re: Check engine light flashes - does NOT set code?? (Bytes U)
The at idle misfire tolerances may need to be increased.
Old Jul 2, 2003 | 02:33 PM
Buckmaster's Avatar
Buckmaster
Cruise-In V Veteran
St. Jude Donor '03-'04
Default Re: Check engine light flashes - does NOT set code?? (Godspeed)
Interesting.....is this because of larger cams in stroker motors?
Old Jul 2, 2003 | 06:26 PM
Godspeed's Avatar
Godspeed
Senior Member
Default Re: Check engine light flashes - does NOT set code?? (Buckmaster)
:yesnod:
Old Jul 2, 2003 | 06:46 PM
Bytes U's Avatar
Bytes U
Thanks for the tip Godspeed... I'll have that looked into. :thumbs: :thumbs:
Old Jul 2, 2003 | 07:23 PM
Buckmaster's Avatar
Buckmaster
Cruise-In V Veteran
One more question Godspeed. How is this value displayed in Edit? If it hasn't been adjusted after the mods were installed.....what should it be adjusted to?
Old Jul 2, 2003 | 08:48 PM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Set all values to 32000 in the (idle by cyl), (low RPM by cyl) and (low RPM) misfire detection tables. this works good for big cams.
It's better than turing misfire detection off because you still get detection at higher RPMs in case you get a bad plug or wire:)
Old Jul 2, 2003 | 09:03 PM
gojo's Avatar
gojo
Default Re: Check engine light flashes - does NOT set code?? (Flyin'Brian)
:iagree:
You also will not get caught, for turning it off, if you have to go through the OBDII emissions.
Old Jul 2, 2003 | 11:40 PM
Buckmaster's Avatar
Buckmaster
Cruise-In V Veteran
Thanks Brian..........exactly what I needed to know :cheers: :seeya
Old Jul 3, 2003 | 08:30 AM
Bytes U's Avatar
Bytes U
Thanks Flyin'Brian for the details on code adjustments.
Old Jul 3, 2003 | 01:36 PM
Flyin'Brian
Cruise-In I Veteran
No prob guys :cheers:
I hope that fixes her up :yesnod:
To Check engine light flashes - does NOT set code??
