KR only in 4th???
With my latest tune I gained 2 mph in the 1/8th mile, but nothing in the 1/4th.
There seems to be a slight hesitation when I shift into 4th.
What else could it be?
I only notice it at the track, of course I don't normally redline 3rd on the street.
What type of intake do you have? Any Cold air intake that has any RAM effect at speed could be causing a lean condition that you don't see at lower (less than 4th gear) speeds.
I have a Vararam.. And it was very pronounced that it was happening to me..
And when I was tuning for the additional air over 60mph I had a similar problem.. I'd do testing on a deserted road and when I hit 4th I was usually well over 80 to 90 and I was getting lean. I added 1% more fuel and extinguished the K/R..
Monitor your o2's they may show you what is happening.
At WOT (Open Loop) the MAF is still reading the additional air but....The PCM just refers to what ever setting the enrichment is at for that MAF reading. If it was perfect before the addition of the Vararam it will be too lean after. With the Vararam it's not enough fuel at that point. It is certainly a repeatable condition when logging. Your O2's get real lean and there is Knock.
At WOT (Which this conversation is about) Fueling is determined ONLY by what the Enrichment settings are in the PCM. If you are on the edge of leaness before the addition of the Vararam then you most certainly will be lean after it.
You are still Correct but you are missing the point... you are suggesting that the MAF can compensate for the 5PSI of an S/C.. True.. ONLY after the Enrichment MAPs have been set properly in the 1st place. If you just stuck that S/C on with no tuning and went WOT you'd Knock and melt the motor into slag.
On to the Vararam.
The Vararam has no real ability to introduce turbulence..even with the dividers. It is a sealed plenum and at "speed" there is a slight positive pressure so Turbulence is not the factor.
One the enrichment MAPs are set to handle the more positive airflow at speed you will be all set for good.
The MAF is ALWAYS doing it's job.. And at WOT is is the tables that determine enrichment.
The open/closed loop thing has nothing to do with it..AT ALL. During closed loop the PCM uses the MAF reading AND the 02 feedback AND MAP AND IAT AND etc. etc. to reach what it knows is 14.68-14.73. This is all in the Fuel/Air Multiplier table. It's a calculation, nothing more. 4000hz does not mean XXX amount of fuel, it just helps in the calculation. The overall calculation is based on about 10 or 11 tables/readings. When in open loop, the F/A Multiplier table is ignored and the VE, MAF, MAP, IAT, PE, etc. determine fueling. There are much, much better ways to tune for a knock in 4th gear only than just adding to the PE table. Use a wideband if you're going to do that.
And no, it's not impossible to run lean in closed loop. An intake leak around only a couple of ports will cause it to run lean on those cylinders even if the PCM is compensating by adding to the LTFT's, that's just an average. The only way a motor would NEVER run lean is to have EGT's/02's for each cylinder.
And again, no, the MAF is the primary fueler when used, although it can be tuned out ie speed density. I've set cars PE tables all to 1.00, so no additional fuel anywhere based on PE, and been able to easily manipulate the MAF table to get the A/F perfect all the way across.
Also, by using the PE table to add fuel you're going to be running rich in the slower gears if what you're suggesting is true since you won't get that "ram air" the the VR supposedly causes. So, run rich in all your gears just to compensate for a supposed condition caused by the positive pressure in 4th. Well, it's not my car..........
This is a contradiction. If the Multiplier table was being ignored then I would see ZERO results when I logged WOT Runs. I in fact saw significant changes. The F/A Multiplier table is most certainly used during WOT. What else would it be used for and why?
I was referring to a normally operating motor. Closed loop will not allow for lean conditions..
You are saying that that as long as you do not exceed the Frequency of the MAF then if can adjust for all fuel needs?? This would ONLY be correct if you upped the tables at the frequencies that show up under WOT conditions. It seems you have tons of experience with FI Cars. I personally think it's a HUGE mistake to tune a NON Forced Induction car by manipulating the MAF Tables.
Assuming you are correct and that I am getting zero ram effect.. Then I wont be lean in other gears. The MAF is going to read EXACTLY the same amount of air at ANY RPM regardless of gear. 6500 rpm in 1st gear will be the same MAF frequency as 6500 in 4th gear. The motor is one big vacuum pump. Also the MAF has no idea what the load is. The throttle position will be needed for that calculation.
Not Sure what you use to tune your car but I use LS1-Edit. You have control over the PE across all RPMs. My car in fact has a Flat PE (Same Value across the board) I tuned it on the Street using K/R as my Lean point. I leaned 1% at a time till I got K/R. Then I backed off 1%. It was perfect according to me. I then took it to a WB Dyno and have a printout that proves it is perfect
All points addressed above.
Back to the original point...
He can fix the K/R easily with a PE change..
Power Enrichment can be set at any RPM or RPM range. That's why it's called the "PE table" and not the "PE setting."
Michael
Greg
Dave
