C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
hypertech power programmer problem?
Old Aug 11, 2004 | 09:46 PM
1SLANDON's Avatar
1SLANDON
Default hypertech power programmer problem?
I downloaded the Hypertech tuning into my practically stock 97 C5 A4 on tuesday morning. Nothing to agressive. Mid ranges on everything. I drove it all day tuesday with no problem that i noticed. Tonight as i'm driving up to the grocery store i notice that the oil pressure needle is buried. I check the digital read out and it is at 128psi. I stopped the car immediately and turned it off. The pressure slowly reduces. I just checked it and it is back down 92psi after being in the garage for 20 minutes. When i stopped the car i happened to have the programmer in the car and reinstalled the stock program. No change in the oil pressure problem when i restarted the car. I drove home with no explosions but.......?
Any ideas of what the problem might be?
Old Aug 11, 2004 | 09:51 PM
90 droptop's Avatar
90 droptop
It's not the HPPIII, it's your oil pressure sending unit. Easy fix behind the intake.... do a search.
Old Aug 11, 2004 | 10:03 PM
1SLANDON's Avatar
1SLANDON
Did the search. Found it. Thanks. Will fix in the morning. Thank God I have a dealership with a good parts department close by.
Old Aug 13, 2004 | 10:58 AM
bk97's Avatar
bk97
1SLANDON, How did the program work performance wise? Power, shifts, etc.
Old Aug 13, 2004 | 09:04 PM
Mike Mercury's Avatar
Mike Mercury
1SLANDON; I noticed you have an A4. Just a note: the Hypertec will not do gear scaling on the C5 (though it works fine on F-Bodies).
Not a problem if you don't intend to change the rear axle ratio.
To hypertech power programmer problem?
