C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
1571 code--help
Old Dec 13, 2004 | 06:17 PM
Slowhawk's Avatar
0Slowhawk
Former Vendor
Default 1571 code--help
97 C5 M6.
This code keeps coming up with a TCS code---1571. -TCM
Any idea to find out how to fix this?I know what the code stands for,just don't know the fix
Old Dec 14, 2004 | 01:51 PM
pocorojo's Avatar
pocorojo
Originally Posted by Slowhawk
97 C5 M6.
I've got the same code coming up. My problem was traced back to the ABS/TCS computer module. Unfortunately, on the 97's, the computer board that appears to be at fault is inside the ABS module, located in the rear of the car. Later models have this computer located inside the front passenger wheel well, separate from the ABS unit. It's an easy fix for those guys. For us, it's an $800-$1000 job. For now, I'm just re-setting the DIC.
Old Dec 22, 2004 | 08:54 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
This should help you out.
C5 CODE LIST
Old Dec 26, 2004 | 08:47 PM
bowtiebandit's Avatar
bowtiebandit
History DTC P1571 Stored and Will Not Clear
Condition/Concern:
Vehicle may have a DTC P1571 [ASR (Automatic Slip Regulation) Desired Torque Circuit] stored in history that cannot be cleared. DTC C1277 (Requested Torque Signal CKT Malfunction) is NOT present and there is No Service Vehicle Soon lamp or powertrain related lamps on.
Recommendation/Instructions:
This is a normal condition. All 1997 YBs will have a DTC P1571 stored as history in the PCM that cannot be cleared. If P1571 is current, follow the trouble table in SI Document Number 101551. It should be noted that the schematic in this document incorrectly lists a ckt 449 dk blu/wht and calls it Real Time Dampening. This ckt is not present and should be ignored for both 97 and 98 (Document Number 203769) model year SI. A Service Information Update has been submitted.
Old Dec 26, 2004 | 09:20 PM
Mike Mercury's Avatar
Mike Mercury
WOW bowtiebandit; way to come-through with the information.
To 1571 code--help
