Is an LS2 timing set a single row?
Old Jan 25, 2005 | 02:39 PM
Fast one's Avatar
Fast one
Default Is an LS2 timing set a single row?
And would it fit an LS1 without any changes?
Old Jan 25, 2005 | 02:46 PM
70 LS1's Avatar
70 LS1
Yes and Yes. You can get just the chain and re-use your sprockets. GM part # 12586482.
Old Jan 25, 2005 | 02:58 PM
d55guy's Avatar
d55guy
Just curious but why would you want to?
Old Jan 25, 2005 | 03:40 PM
John Nowak PE's Avatar
John Nowak PE
The LS2 chain has much thicker side plates. Therefore, a much stronger chain.
Old Jan 25, 2005 | 05:02 PM
Fast one's Avatar
Fast one
I ordered a QTP two piece front cover with oil pump which requires a single row chain set. Thanks for the quick reply, the chain set was ordered from Fred Beans while the special is on.
Old Jan 25, 2005 | 06:27 PM
d55guy's Avatar
d55guy
Cool. I had no idea.
To Is an LS2 timing set a single row?
