Help!!! Drain plug broken!!!!
Old Jan 27, 2005 | 04:12 PM
12stepvette's Avatar
12stepvette
St. Jude Donor '03-'04-'05-'06-'07
Default Help!!! Drain plug broken!!!!
I decided to drain and flush the radiator today...the drain plug is a push and pull affair, kinda like a wing nut zus fastener...well it broke!! I turned it counterclockwise and it snapped off!!!
I have it partially extended and antifreeze is draining...how do you remove the plug to replace it??? and is it a replaceable item???
Help!!!!
Sorry I mistakenly put this post in the general C5 section also..
Old Jan 27, 2005 | 04:17 PM
Shylor's Avatar
Shylor
You will most likely have to remove the radiator to deal with this correctly.
Old Jan 27, 2005 | 04:28 PM
12stepvette
why would the radiator have to come out???
I can grab whats left of the plug....but before I do...is it removable??
Old Jan 27, 2005 | 04:30 PM
devo's Avatar
devo
St. Jude Donor '03 & '05
dude give me a call same thing happened to mine
dean
Old Jan 27, 2005 | 09:46 PM
LoneStarFRC's Avatar
LoneStarFRC
Don't panic. It is removable. Use a small pair of needle nose pliers and pull it straight out. It may not be broken. After wiping off, make sure the o-ring is still on it and OK. Re-insert firmly until it stops, then use a 1/4" drive in the square hole and gently rotate 1/4 turn clockwise. Do NOT get gorilla handed with it. HTH
Robert
Old Jan 27, 2005 | 11:28 PM
12stepvette
First off, I gotta say thanks to Dean for the reassuring Phone call....
Next, Let me share all that I found out about our little friend, The radiator drain plug!
The earlier vettes, `97-00 have a drain plug kinda like a wing nut. These were prone to breaking right where mine broke, at the shoulder! Then in `01, they came out with a much better plug that was thicker at the shoulder and used the 1/4 " drive in the center for turning.
The Plug has a 1/8" steel pin that rides in a groove and allows exactly 1/4 turn from fully closed and locked to fully open and draining. Halfway between fully open and fully closed, is where the pin aligns with a slot and you can pull the plug straight out for replacement.
Wish I had a photo of the plug, But the part number is, 52484010 and costs 3.66.
I can assure you all....the radiator does not need removal for the plug swap!!
Old Jan 28, 2005 | 02:04 AM
Shylor's Avatar
Shylor
Glad it worked out for you.
Old Jan 28, 2005 | 06:30 PM
LoneStarFRC
Glad to hear you're OK on the plug thing!
BTW, the plug on my '99 is also as you describe. I use a 1/4" drive nut driver to remove it. Since I bought it new (late Mar '99 build date), I know it has not been retrofitted.
Old Jan 28, 2005 | 06:38 PM
2KREDVert's Avatar
2KREDVert
My 2000 already has the 1/4" hex type too. Never was changed. The parts listings also do not show a revised P/N for newer plugs. The same P/N is listed for the '99, 00 and 01 as is listed here, 52484010.
Old Jan 28, 2005 | 08:14 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
That's good news. I think I broke that pin off in mine last year. As the plug just spun around in the hole. I just screwed it back in and hoped for the best. It's been holding ever since. But, now I know I can replace that piece at some point down the road.
Old Jan 28, 2005 | 11:11 PM
12stepvette
My Parts manual is broken down into two sections for the Cooling section... Years `97-2000, and `01-2004, So I naturally assumed thats where the divide came in for the upgraded Plug...Looks like it might have been incorperated as early as `99.
Old Jan 28, 2005 | 11:40 PM
TEXHAWK0's Avatar
TEXHAWK0
So will this plug fit all years through 2004?
Old Jan 29, 2005 | 10:39 AM
12stepvette
Yup!! `97-2004 Factory Radiators.
Its new and improved!
To Help!!! Drain plug broken!!!!
