1/4 ET Help
Old Jan 28, 2005 | 08:05 AM
LAYNLOW's Avatar
LAYNLOW
Default 1/4 ET Help
My "04" C5 was just dynoed at 475 rwhp. It has a/t w/shift kit and a 3.15 gear w/3200 converter.
I'll be running BFG drag radials.
Assuming all circumstances are right, weather, traction, etc.
What would be your best guess for a 1/4 ET and MPH.
Old Jan 28, 2005 | 09:40 AM
TLKSCHP's Avatar
TLKSCHP
I don't have a clue but if I'm right do I get a prize
11.10 at 127 first time out
Old Jan 28, 2005 | 09:50 AM
LAYNLOW's Avatar
LAYNLOW
I'll let you know how close you are when I find out. It's freezin A#* here so it's going to be awhile.
Thanks for your info!
Old Jan 28, 2005 | 10:04 AM
TLKSCHP's Avatar
TLKSCHP
Don't feel alone, it's snowing here
Old Jan 28, 2005 | 10:08 AM
LAYNLOW's Avatar
LAYNLOW
Better days are right around the corner.
We're on the home stretch.
Old Jan 29, 2005 | 08:46 PM
MikeV's Avatar
MikeV
Put it this way. . . You better put in the required safety equipment like a roll bar or you will only get one run . The real answer to your question all depends on track prep, elevation, and drivers experience. Range could be low 12's to low 11's at 125 +/- 3 MPH.
Have fun... but be safe.
Mike V
Old Jan 29, 2005 | 10:20 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
My question is can you put that 475 to the ground?? If you can, then you should be in the 10"s.
Old Jan 30, 2005 | 12:03 AM
Vettegetsmwet99's Avatar
Vettegetsmwet99
Exactly!, if you have some et streets and know how to drive then it would be easy to get to 10.7-10.9 range. I dont think drag radials will give you enough traction to get that kind of run but they might, your on the borderline as far as power/traction with dr's.
Old Jan 30, 2005 | 06:57 AM
Mitch C's Avatar
Mitch C
DRs won't give you the traction needed with 475 RWHP. You need ET Streets. BTW what mods do you have to get to 475 RWHP with an A4?
Old Jan 30, 2005 | 10:52 AM
Sorry I Bought An A4's Avatar
i get mid 11's with 430 rwhp
Old Jan 30, 2005 | 11:11 AM
Doczo6's Avatar
Doczo6
Mid to low 11's with low 120 traps if it hooks
Old Jan 30, 2005 | 07:22 PM
LAYNLOW's Avatar
LAYNLOW
Thanks guys!
I've been going to the track a long time, but never with a new car like a vette. I had a low 11's 68 Camaro a couple of years ago but things are so much different with that. I ran a 4.56 gear, open headers and rattled my fricken teeth out of my head. This is why I didn't have a good handle on the capability of my vette with this hp.
As for drag radials I see these guys breaking into the seven 7's & 8's running these. I want to stay away from the ET street etc, until I change my output shafts. I hoping the BFG's hold up seeing the UPS guys tracks are still in my driveway.
To 1/4 ET Help
