Front Turn Signals
Old Jan 28, 2005 | 05:39 PM
FRC4MEAM's Avatar
FRC4MEAM
Default Front Turn Signals
Need to replace the front turn signals and wanted to know if this was straight forward or are there some tips to doing it? Looking at the replacements, it doesn't appear that it is going to be difficult, but you know what they say, sometimes looks are deceiving.
Old Jan 28, 2005 | 07:44 PM
leaftye's Avatar
leaftye
Pretty straight forward. If your arms are thin, or know someone with skinny arms, the bulbs can be accessed thru the brake duct holes. The ducts push out of the way. Super easy, takes less than a minute.
Old Jan 28, 2005 | 11:23 PM
silverz06vette's Avatar
silverz06vette
Old Jan 29, 2005 | 01:51 AM
Goody's Avatar
Goody
You can remove the small access panel under the brake ducts in only a few minutes and have plenty of roam to do the work, clean stuff and ......
Old Jan 29, 2005 | 02:19 PM
stngdsn's Avatar
stngdsn
changed my right front about an hour ago. Wife had to reach in, I couldn't get my arm in there.
Old Jan 29, 2005 | 02:41 PM
FRC4MEAM's Avatar
FRC4MEAM
Thanks for all the information. Had the same issue with tight spaces, so had my father replace the lights. We even went one step further and installed the European front lenses to match the rear ones.
Old Jan 29, 2005 | 09:18 PM
JiminFL's Avatar
JiminFL
I reached in from above by putting the headlights & hood up and reaching down between the hood, the hinge, and the light shroud. It took a bit of experimenting and a serious degree of commitment to the project to get my arm in that far, and taking 5 more minutes to remove and replace the plastic headlight shrouds would've been wiser in retrospect, but I got 'em done.
To Front Turn Signals
