Oil temp low...
Old Jan 28, 2005 | 06:47 PM
1230'sc5's Avatar
1230'sc5
Cruising
Default Oil temp low...
After the car has sat for a month, I took it out today and after starting the DIC said low oil temp. It made sense since it's been cold here for a while. After the car is warmed up it never displayed any tempreature readings, just low oil temp. Any ideas would be appreciated.
Old Jan 28, 2005 | 06:57 PM
allanlaw's Avatar
allanlaw
Sure it isn't saying "low oil level"?
Old Jan 28, 2005 | 07:00 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I had the same problem in my 98 coupe once. I drove 70 miles in 15 deg temps and it never got above 130 deg. I was very concerned and made a post when I got home.
Come to find out, if you select oil temp and monitor it. The temp that it is at when you pull it up on the DIC is the temp that it will stay at. I have never tested it on my 02 Z06 but I know it works that way in the 98!
To test it out, drive the car until the oil temp is at a low readable temp and leave it there for 30 min. Then select another function on the DIC and then go back to the oil temp and see if it reads the correct up-dated oil temp.
Bill
Old Jan 28, 2005 | 07:52 PM
GTC's Avatar
GTC
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05
Yes, I saw "Oil Temp: Low" on my DIC last week. It really freaked me out because I had never seen it before. And yes, it was freezing cold, about 16 degrees F. I looked through the owners manual and it said nothing about oil temp low, but there were plenty of other dic messages. I thought it may have meant oil level low, so I checked the dipstick, and the oil level was fine. Driving to work, it only said oil temp low, and I know the temp had to get over 150 before I got to the office.
Then I did a search on the forum, and there she was. Apparently it only does this when the oil is really cold, and it won't clear the oil temp low message until you turn it off, and turn it back after the oil temp has gotten above a freezing temp.
Old Jan 28, 2005 | 11:20 PM
gsxrjack's Avatar
gsxrjack
yup, same thing with me last week...was like dam, just read of 3 oil temp sensors going bad in here and now mine is,...selected another function and went back adn all was good...whew
Old Jan 28, 2005 | 11:35 PM
Shylor's Avatar
Shylor
This doesn't make any sense for the temps not to change on the DIC. I've never seen what you are saying happen on my 03 Z06. I routinely run my car up to temps with the DIC displaying oil temp. I let it run and watch it until the temps get past 212 degrees for about 5 minutes (to boil off any moisture in the oil).
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
My oil says 13 right now
Old Jan 28, 2005 | 11:44 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
When's the last time you started it cold below 15 deg F?
That's when this seems to occur...and yes it is normal.
If the oil temp is below 15, you will get a DIC reading of "low" instead of a degree display. The glitch in the system is that it does not go away until the next ignition cycle. You can drive the car for an hour, it won't change....but if you drive it for 5 mins, shut it off, then restart it, the actual oil temp display will resume.
I've driven my car many times in single digit temps, and this always occurs.
Old Jan 29, 2005 | 03:09 AM
Shylor's Avatar
Shylor
This is what I'm saying isn't correct. Not about the DIC reading "Low".
Old Jan 29, 2005 | 11:01 AM
1230'sc5's Avatar
1230'sc5
Cruising
Default Low oil temp
Thanks for the heads up, I am going out for a cruise and will shut it down after a few minutes and see what happens.
Old Jan 29, 2005 | 05:45 PM
MY1STPEWTER's Avatar
MY1STPEWTER
I've gotten this message one time. When I started it up it was quite cold. I'd never seen it before so after running for a few minutes I turned it off and back on and was still there. Went ahead and drove it for a while and then made a short stop of 5 or ten minutes and then got the correct reading after restarting. I know I had let it run long enough in garage for the reading to not have been that low, but apparently has to be several minutes wait in between restarting.
Old Jan 30, 2005 | 07:24 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
On the 98 I use to have to select something else on the DIC and then go back to the oil temp to get an accurate updated reading. POOR DESIGN! I just broke the 02 Z out of the garage to take her for a drive, bust the rust off of the rotors and wash it when I was done ( IT WAS 40 Deg here in CT today!!! ) and while I was out I monitored the oil temp! Guess what? Some engineer realized his mistake and it up-dates all by it self with out having to select something else!
I wonder what year it was corrected?
ANYONE??
BC
Old Feb 2, 2005 | 06:45 AM
Patman's Avatar
Patman
I get this problem all the time, and it annoys me. If the oil temp is lower than -9C, it just says oil temp low, but never comes on even once the oil gets hotter. The coolant temp is the same, except when it does hit -9C it then displays.
As others have said, if you shut it off and restart it when the engine is warm, the oil temp will display again. A very poor design indeed.
Old Feb 2, 2005 | 07:09 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Try cycling the display to something else like tire pressure or Avg Fuel MPG and then back to the oil temp. If it is still displaying the same thing, you have a prblem with that sensor or wiring.
BC
Old Feb 2, 2005 | 07:43 AM
PaPaChoc's Avatar
PaPaChoc
ANYONE??
BC
My 01 is that way. When I start it I watch the temp till it gets to 100, by then it's warm enough to Check It Out!
Old Feb 2, 2005 | 08:32 PM
Patman's Avatar
Patman
BC
Cycling it from one display to the other doesn't work. It's obviously not a problem with the sensor or the wiring since everyone on here reports the same thing when it's cold. So it's a design flaw in the unit.
Old Feb 2, 2005 | 09:16 PM
leaftye's Avatar
leaftye
Just trying to make sure I understand this...
This only affects 98's.
The low oil temp message will come up if the temp is 15 degrees or less.
If the car is started with a low oil temp message is received, the oil temp on the DIC will not be updated until the DIC screens is changed to something else, and then switched back to the oil temp screen. Restarting the car after the oil temp comes above 15 degrees will reset the system, and it will work properly, but restarting the car is not necessary because the DIC will update the oil temp if the DIC screens are changed (like oil temp to fuel mileage and back).
If the car is started without a low oil temp message, the oil temp on the DIC will be updated.
Anything wrong? Anything missing?
To Oil temp low...
Old Feb 2, 2005 | 09:31 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
No, AFAIK it affects all C5's. I have a 2001 and have seen this display numerous times.
Correct.
To clarify, it does not appear automatically like a warning message...but if you select the oil temp display by scrolling the gages button, it will simply say "low" instead of showing a degree reading.
No, the low oil temp display will not disappear or update just by changing the DIC display.
Yes.
No, because simply changing DIC displays does not eliminate the "low oil temp" display.
Yes...it should.
I think the problem BC added to this thread is not the same as the "low oil temp" problem, and tt seemed to add much confusion here. If you get an actual degree reading when viewing the oil temp display, it should update. If it doesn't, there is a problem.
If all you see is "low" when viewing the oil temp display, it will NOT update no matter what the oil temp rises to as you drive the car, until the car is restarted when the oil is warm. This is NOT a sensor or wiring problem, it is a programming flaw.
This "low oil temp" thing gets reported here every year, and most everyone who uses their car in very cold conditions has experienced this.
Old Feb 3, 2005 | 12:18 AM
Bill Dearborn's Avatar
Bill Dearborn
I've run my 97 and my 03Z in single digit temps and have seen the low oil temp warning many times but have never noticed the syndrome you are describing. Since I had an engine oil cooler on both cars I had to monitor the oil temp before I could push the car and I never noticed it wouldn't change.
Bill
Old Feb 4, 2005 | 01:50 PM
allanlaw's Avatar
allanlaw
I've learned a lot from this thread. Being in SoCal, I might have gone through the rest of my C5-owning career without ever seeing the "low oil temp" message on the DIC.
