A4 Tech Challenge-need Help!!
Old Jan 30, 2005 | 10:28 AM
ANTHONYCORVETTE's Avatar
ANTHONYCORVETTE
Default A4 Tech Challenge-need Help!!
I swapped my 98 a4 for a 03 a4 due to the fact i had to replace a bellhousing and torque tube....good time to update tranny. Before i installed the tranny i had hp tran shop look at and they said looked good so they replaced a band and filter. while they were in there i had them install billit servo, oversize.490 valve for pump, put shift kit in and i had them remove ball from input shaft. in addition i put in 3000 vigilante converter.
PROBLEM: CAR DRIVES GREAT HAVE 15 MILES ON THE CHANGE. AROUND 50 MILES AND HOUR AFTER DRIVING A FEW MILES STEADY THE TRANS MAKES A CHANGE AND STARTS SLIPPING IN 4TH. IN ADDITION WHEN YOU SLOW DOWN IT BANGS 2ND AND 1ST DOWNSHIFTING AND THE SAME IF YOU TAKE OFF AGAIN-HARD 1ST AND 2ND SHIFT AND NO 4TH LOCKUP. IF YOU STOP CAR AND SHUT OFF AND START BACK IT DRIVES GREAT UNTIL YOU GET AROUND 50 MPH STEADY FOR LONG PERIOD....THOUGHT ....MAYBE TC APPLIED VALVE IN VB. THANKS IN ADVANCE.
Old Jan 30, 2005 | 10:55 AM
VetteTech81's Avatar
VetteTech81
Sounds like problem with the valving some where. possibly a few problems. I would contact the shop that installed the shift kit, ect and talk to them. I've read about the firmer TC apply with the check ball removed but never tried it. So I havn't experianced the results first hand with it. around 45/50 thats when the TC is supposed to lock up so to me I would start looking into the solenoid and valving ect for the TC.
I'm thinking too is the trans really slipping or is the converter just not locking up in 4th?
Either way I would talk to the trans shop that did the work.
-=Rick
Old Jan 30, 2005 | 12:10 PM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
Check your codes...sounds like P1870...but you don't mention any check engine light being on. It could be just because of the amount of slip the PCM is sensing due to the new TC. When I installed my SY3500 I had same issue and had the parameters for sensing slip and setting that code widened in my PCM. No probs. at all since that.
Old Jan 31, 2005 | 09:08 AM
ANTHONYCORVETTE
When the trans started to slip @ around 50 mph it kicked the 1870 code. I had the trans shop place a shift kit that was suppossed to help with controlling the 1870 code(boost valve). Is there a tc silonoid or applied valve that are for controlling this action. It seems strange that it happens only @ 50 for a steady period of time..the tran shop does not have an idea...yet...any thoughts
Old Jan 31, 2005 | 09:46 AM
Dave00C5's Avatar
Dave00C5
That sure sounds like P1870!! You'll have to have the slippage compensated for in your programing. Don't drive it much until you do because it will eat up that torque convertor in a hurry. In the meantime drive it in 3rd as it won't allow it to lockup and trip the p1870.
Old Jan 31, 2005 | 11:35 AM
sweetcharity
50mph is when the PCM starts reading data for this condition. Up a steady hill at that MPH and it will set in a few moments. I think that you are ok to drive it to have the PCM edited to allow for the "indicated slip" it is sensing. If you reset the DIC I think it will behave normally until you again cruise at 50mph for a bit in locked up mode. Have whomever did the programming for your new gears and TC widen the parameters for allowed slip and you will be fine.
Old Jan 31, 2005 | 02:03 PM
ANTHONYCORVETTE
thanks for the advice but when it trips the code does it change the parameters for the tranny. when you are driving along @ 50 in lockup mode for a length of time 4-5 miles steady it instantly starts slipping and when you slow down it bangs 2nd and 1st on the downshift and hits hard on 1st 2nd upshift. when you stop shut off car and re start it acts fine again....until 50 mph steady. and yes the 2nd time the check engine light came on. I cleared the 1870 and the light went off and ok again until 50mph steady....ANY THOUGHTS ON THIS...DOES WIDENING THE 1870 PARAMETERS CHANGE ANYTHING....WHAT IS TRIPPING THE TRANSMISSION CHANGE
Old Jan 31, 2005 | 07:02 PM
VetteTech81
One thing to note is... After the 1870 code pops up the computer should (in it's stock form) counter act the precieved slippage and up the line pressure to provide more holding power for the band and clutches. This raise in line pressure can cause the banging down shift. I think the tuning needs to be taken care of first here. Due to the new Torque Converter.
-=Rick
Old Jan 31, 2005 | 07:10 PM
sweetcharity
Yes to the above.....thats exactly why it is banging the 1-2 shifts. The line pressure is automatically set to max to counteract any slippage in an attempt to save your tranny when the code P1870 is set.....TAKE IT BACK TO THE TUNER AND HAVE THE PARAMETERS WIDENED!!! When it happened to me and I felt the shift, I about crapped my pants!! It is a little unsettleing to say the least!
(This is assuming that there are no other problems going on. If your tranny was slipping badly there would be some high temps associated with that. Sooo ruling out a bad transmission the above is the way to go)
Old Jan 31, 2005 | 08:34 PM
ANTHONYCORVETTE
thanks for all the help!! the trans temp seems to stay between 185 and 195 max. do you recommend LS edit----not sure what the software costs but the the closest tuner is the other end of florida. Is Ls edit a good investment...thanks for all the help again
Old Jan 31, 2005 | 09:40 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
LS1edit or HPtuners are both great investments, you can tweak what ever you want and they will both retain their resale value incase you sell your car.
Personally I prefer HP Tuner because it comes with it's own scanning software, if you buy LS1 edit then you'll also need to buy a scanning software like Autotap, the other benefit to HP tuner is it is locked to a model year so if you buy the software for a 98 Corvette then you can use it on any 98 Corvette but if you buy LS1 edit it's locked to a VIN and you can only use it on those VIN's.
To A4 Tech Challenge-need Help!!
