Can't remove water pump housing.
Old Jan 31, 2005 | 09:24 AM
Fast one's Avatar
Fast one
Default Can't remove water pump housing.
I removed 6 long bolts from the water pump housing and it won't come off the block. Are there more bolts that need to be removed or are the gaskets holding it on?
Old Jan 31, 2005 | 09:25 AM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
nope...6 bolts and all the hoses. I pulled mine on Friday, and have to do it again on wed. or thurs. Best of luck to you!
Chris
