Harsh Ride with F55
However, when I am on the freeway at 70MPH and I hit a part of the roadway where there is a transition, say between some old pavement and some new pavement, the car takes the hit pretty hard, almost seems like it bottoms out to me (it is quite jarring). Now, this only happens when the there is a pretty good difference between the pavement heights, most of the time, the ride is fine (a hard transition in the pavement like this only occurs once during a ride of 50 miles or so). However, if I take any of my other cars over the same bump, it seems like a regular bump (you notice it but it is not jarring). In the Corvette, it hits hard .
Everything else seems pretty normal; no codes in the DIC...
Given that I am new to the Corvette, is this normal? Am I just being a wimp
? Anybody out there with F55 have a similar experience?
? Anybody out there with F55 have a similar experience?I have not noticed any problems, however there was an issue when the system first came out, they put these yellow or orange stops on the shocks for transport. Many of the dealers were not removing them during the dealer prep and it was causing driveability issues.
Try taking a look at the suspension for anything odd (like big yellow plastic pieces on the shocks)
Chris
Smooth (or slow) out the bump, and the tires absorb less energy, which is then controlled by the suspension.
HTH, and have a good one,
Mike
Now....I think at somewhere around 80mph the system switches itself to "sport" mode so that also could be your ride quality.
I notice it myself on my AE but it is still softer than a Z51
Chris
I did those two mods about a week apart but did not test this - was focused more on cornering, so I can't tell you if one made more of a difference than the other. But combined these two are excellent.
It is also nice for daily driving. Comfortable drive without being sloppy as it was completely stock. Sport mode is tons nicer as well.
Mike
MR seems to be less effective in damping this kind of harshness presumably because, even with a 10mSec response, with the car moving fast, it can't react quick enough to bring the most ideal damping to bear. While this harshness is a shortcoming, the types of surfaces that cause it are fairly rare.
In fact, this might not be entirely an MR issue. The stiff sidewalls of C5s run-flat tires amplify this type of harshness to the suspension. Rumor has it that C6 will have a new, Goodyear EMT with vastly improved harshness qualities and that might solve this problem.
Hope this helps.
You can jack up your car, either from below the cross frame with a block of wood between the floor jack and the cross memeber, or at the four jacking points at the edge of the rocker panels toward the front and rear, and remove them yourself. Your wheels need to be off the ground, so Rhino Ramps will not work for this procedure. Goood Luck!
mtv
Thanks.
Thanks.
Thanks.
Any other probs...PM me.
Dan
