Someone please help...My 2000 roadster is going wacky with alarms and prompts on the info display showing service soon, etc. The windows and radio won't work and I can't get the top up! I've had the battery replaced ( AC Delco pro series). It ran Ok for about a month and now it's gone crazy again! Any help would be greatly appreciated.
- Vince
Check your ground wires. Not sure if this is all of the major ones, but:
Battery Black grounding
Starter Ground
2 grounds behind the headlamps.
Good Luck, but don't freak, its probably a loose ground wire.
When tightening a ground wire, be careful.
I'm going thru the same sh!@ except mine doesn't do it every time. It always starts though...In the process of getting time to go over all my grounds. Also checking all my relays....
