Guys, I'm contemplating a cam install. Due to budget constraints I won't be able to do the heads at the same time so I want a cam that will satisfy me in the meantime. I was thinking of the Magic Stick, LG5X3 (114) and also heard some good things about the Futural FM-13??? I would like the car to remain streetable (use the AC), I love lope, don't want to have problems with excessive stalling or bucking while cruising at highway speeds and IF I did go with a set of AFR heads in the future do not want to fly-cut pistons. Not sure if I'm asking to much here but would appreciate any feedback or experience.
I have a Comp 224/581/114. Nice lope not wild. Headers will help power also. Great power from 2000-5500rpm. Make sure you get a tune afterwards to get the most out of it.
I have a 224/228 114 cam and wish I would have went with a 112 or even larger cam all together. Driveability is perfect with this cam and you can still use 5th and 6th gear with no bucking.
the FM13 is a great all around cam. lots of people are running it with no complaints
The FM13 is a great cam, it makes great power and is VERY street friendly for a big cam. In fact most of Allan Futrals cams are known to make great power and have excellent street manners. The specs are 230/232 595/585 (your choice of LSA). Do a search over on the LS1tech forum, lots of FBody guys are running the FM13. You might want to give Allan Futral a call he is very helpful and really knows his stuff. His web address is www.futralmotorsports.com Good Luck
Thanks Mitch. I'm hearing quite a bit on the LG and the Futral but nothing on the Magic Stick. Does anyone know anything about it or has seen it perform? I know Lou keeps his #'s a secret, but is there any speculation on the specifications of the LG cam?
go to ls1tech.com and do a search on the magic stick. youll get all the info and reviews you need
Some people over on LS1Tech claim they have run 10s with the magic stick. It is a very big cam and is not for everybody when it comes to street manners.
