LS1 Edit why?
General Motors tuning? Exactly.
If you're stock, you have little need for it. When you get into the big mods, you need to adjust the computer accordingly for the radical changes those compnents will make.
I just added Stainlessworks Long Tube headers, High flow cats, 3" mid section with an X pipe and 3" stainlessworks duel outlet mufflers. My MPG with just the exhaust system improvement dropped to (my best with my foot out of the throttle
) is 25-26 mpg. The significant drop is due to the stock tune conflicting with the better flowing exhaust system. The SAD part about the entire situation is I gained *** loads of power and if I get the computer custom tuned I will have even more HP & TQ and better MPG averages to boot!!!
So,,,,,,,,,,thats one reason why you would need a tune.
The more factors that you change the operating prameters of your engine away from stock the more you need to have a tune done. If all you did was to install a high flow air filter, I doubt that you would gain enough performance to warrent a tune.BC
Plus if your C5 has an automatic transmission, torque-management is robbing you of a fun drive.
There are other options than LS1Edit, that are easier to use; but somewhat limited. But LS1Edit is considered the king of the aftermarket tuning.
Not ready for a LS1 Edit yet.
Is there anything I can do to help the Automatic? with the Hypertech ?
please email rbcox@hotmail.com
If you're running it from your laptop, how do you know how you're affecting the power output without a dyno?
That be said it also a very expensive purchase for a single license. and can only be used for that one car. Its cheaper to go to a reputable tuner shop and have them do it on a dyno with wideband O2
Based on these readings, you use LS1-Edit (and a lot of knowledge) to make changes and upload those changes to the PCM. This is not a simple point and shoot program, you really need to know what you're doing and how changes will affect things.
The repeact the cycle...scan, note the effects, make more changes (if needed).
The best way to know for sure you're making good changes is to use with a dyno....but you can do it by driving the car too.
LS1-Edit is a rather pricey and complex program (around $600 I think)..so unless you change the car a lot, it is not worth it for most people to actually own the program.
If you get all your mods done, then take it in for a dyno tune, they will likely use LS1-Edit to make the tuning changes to the car, and you're done. Unless you change or add new mods later, there should never be a need to retune it.
For what mods you have, tuning isn't necessary and the slight gains you might get from a dyno tune probably aren't worth the cost at this stage. If you are planning more mods, save the dyno/tuning for later.
I suspect your auto to be in that range as well...
Mike
