Torque on wheels
Old Feb 1, 2005 | 08:00 PM
DiamondaDave's Avatar
DiamondaDave
Default Torque on wheels
Whats The Torque on a 2000 vet wheels
Old Feb 1, 2005 | 08:18 PM
02blueelectron's Avatar
02blueelectron
my tire shop uses 220 lbs on their air guns.when i put on my drag radials i use 220 on my electric gun
Old Feb 1, 2005 | 08:19 PM
DiamondaDave
Thanks Dave
Old Feb 1, 2005 | 08:34 PM
purrvert's Avatar
purrvert
100 Ft Lbs, in sequence. Manual specifically tells you not to use air tools!
Old Feb 1, 2005 | 08:48 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Bob
Old Feb 1, 2005 | 09:40 PM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
Is there a relatively cheap torque wrench that can be used for the wheel lug nuts?
Old Feb 1, 2005 | 10:12 PM
Flareside's Avatar
Flareside
If you ever really apply 220 foot pounds, you'll snap the studs right off.
Impact guns should come with a warning label about wheel lug nuts. How many ruined nuts, wheels, and warped rotors have been caused by them?
Old Feb 2, 2005 | 10:09 AM
rapid robert's Avatar
rapid robert
Harbor frt. has 1/2'' for $9.99 and 3/8'' for $16.99.
I got the 1/2'' one for taking the wheels off and cleaning the wheels and under the wheel wells after going to the drag strip. Works fine for me.
Old Feb 2, 2005 | 10:12 AM
JTE's Avatar
JTE
CI 4-7, 9 & 10 Veteran
Old Feb 2, 2005 | 08:38 PM
PDQC5's Avatar
PDQC5
Be careful, the next question will be how do you change a broken stud.
Old Feb 2, 2005 | 09:51 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Looks like your tire shop needs training..................... 100 should be more than enough
Old Feb 2, 2005 | 10:13 PM
Scubanme's Avatar
Scubanme
You'll bust your nuts (lug) trying to torque them to 220ft.lbs
manually... ask anyone who has ever torqued a crank pulley bolt.
Old Feb 2, 2005 | 10:56 PM
VolFan615's Avatar
VolFan615
Yellow C3/C5
If you want to use an air gun pick up a 100 # torque stick.
Old Feb 3, 2005 | 08:16 AM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
HOLY CRA$ Don't use that much - no need to break off studs here.
The GM manual calls for 100 ft lbs
Old Feb 3, 2005 | 08:54 AM
Thunder7's Avatar
Thunder7
WOW! That is a bit high. It is 100 ft. lbs!
Old Feb 3, 2005 | 09:07 AM
sprinter's Avatar
sprinter
Dont buy anything from Harbour Freight! I dont care how much of a bargain it looks. My first order for $90 ended up in the trash can (except for some impact wrench extensions which I use for banging stuff off with a hammer).. the stuff is rejects from China and India
And would you trust a $9.99 torque wrench to give an accurate reading??? I would trust my arm better than that
Old Feb 3, 2005 | 09:14 AM
Ruler89's Avatar
Ruler89
Sears is running a sale on torque wrenches this week. I bought the clicker type for around $50. It was $30 off.
They also had the needle type and they were around $20. These came with the Craftsman lifetime guarantee. The clickers only have a 1 yr. guarantee.
Old Feb 3, 2005 | 09:24 AM
jrose7004's Avatar
jrose7004
To Torque on wheels
