Questions about changing fuel filter
Old Feb 2, 2005 | 04:49 PM
raidersfan's Avatar
raidersfan
From: Spread The Virus!!!!!!! Opie and Anthony XM Satellite Radio
Default Questions about changing fuel filter
Whats up all? I got my WIX fuel filter today for my 97 and I need to know what tool I need to remove the outlet line from the old filter. On the new filter it looks like some kind of pressure fitting.
Old Feb 2, 2005 | 05:06 PM
devo's Avatar
devo
St. Jude Donor '03 & '05
I just changed mine a couple of weeks ago.
BIG PAIN IN THE @SS!
you can get the tool at any auto parts store. I paid 8.00
fuel line / AC removal tool looks like a little plastic collar with a split down the middle. 5/16 i think?
what is a WIX fuel filter???
Old Feb 2, 2005 | 05:20 PM
raidersfan's Avatar
raidersfan
WIX is the brand, It is a big company, They make fuel,oil air filters.
Old Feb 2, 2005 | 05:21 PM
raidersfan's Avatar
raidersfan
so what does the tool do? I guess it spreads open the connector on the filter?
Old Feb 2, 2005 | 06:57 PM
gmblack3's Avatar
gmblack3
Be advised that when I tried an aftermarket fuel filter from advanced auto parts, it did not work right. Filter was killing fuel pressure and car would not hold WOT on the dyno.
I would think that a WIX should be fine.
Old Feb 2, 2005 | 08:07 PM
IFLUBYU's Avatar
IFLUBYU
No it is split so you can wrap it around the fuel line, then push it up into the connector to release it.
Old Feb 2, 2005 | 08:17 PM
Old Timer's Avatar
Old Timer
I got the GM one from the dealer. It was about $9.00. "97 & '98's use the NON-pressure regulator model. BTW, I had to cut the old one off. Due to space constraints I couldn't get the tool aligned properly on the line.
Old Feb 3, 2005 | 11:16 AM
Bling Bling's Avatar
Bling Bling
There is a write up about changing it out in the Tech Tips section
To Questions about changing fuel filter
