Will bad battery make codes appear?
Thing is, I have all these codes showing up (or may have been there before, just got car).
Could a bad battery cause codes to appear?
Here is what I had:
40-BCM -Body Control Module
B0432 Rear Defogger Relay Circuit
B0503 RH DRL Relay Circuit
B0508 LH DRL Relay Circuit
B2588 Column Lock/Unlock Drive (A)
B2723 PASS-Key Detection Circuit
B2592 Column Lock/Unlock Drive (B)
B2583 Column Lock/Unlock Drive (B)
99-HVAC - Heater, Ventilation, Air Conditioning
B0446 Right Actuator Out of Range
A6-SCM - Seat Control Module
B0851 Battery 1 Out of Range
A0-LDCM - Left Door Control Module
B2282 Battery #1 Fault
B2284 Battery #2 Fault
A1-RDCM - Right Door Control Module
B2283 Battery #1 Fault
B2285 Battery #2 Fault
B0-RFA - Remote Function Actuation
U1016 Loss of Communications with PCM
U1096 Loss of Communications with IPC
U1096 Loss of Communication with IPC
U1255 Serial Data Line Malfunction
thanks immensely!
Denis
QUIMBO
SEEYAAAH
EDIT!
it does appear to have leaked at one point in time. How can i tell if there is damage?
Denis
As for acid damage inspections, you will need to remove the battery, remove the passengers wheel and remove the inspection panel that is in the fender well to inspect the PCM and the TAC module. Also look for wiring harness damage and frame corrosion.
The first thing to go if you have acid damage in the wiring harness will be the vacuum lines and the ability to control the HVAC vents.
BC
New battery going in tomorrow, as well as a thourough engine shampoo
what hvac codes would i get if hose went?
thanks
denis
The only symptom will be that you will have NO control over where the air comes out of. Most of the time it will fail to the defrost vent! That is a SURE sign that the vacuum supply is missing.
Here is where the HVAC vacuum supply originates. If it ever comes loose from there,,,man it will be a BITCH to get it back on!!!
thanks Bill (& all other helpfull souls)
Denis
