C1248 - DRP Disabled, what's DRP?
Old Feb 4, 2005 | 09:03 AM
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
Default C1248 - DRP Disabled, what's DRP?
2004 A4, it's cold here and car has been sitting, occasional 30 mile rides every two weeks or so for past two months, no check engine lights; it's a history code so apparently it took care of itself but I'm wondering what it was. Came w/ c1221 & c1222 wheel sensor history codes as well. Any ideas?
Old Feb 5, 2005 | 03:45 PM
BudgetPlan1
Old Feb 5, 2005 | 03:55 PM
Richin Chicago's Avatar
Richin Chicago
Both you RF and LF wheel speed sensors are intermittent. Do you have stainless brake lines installed by any chance? Something is causing an interruption in the data flow from the sensors to the CPU. Ususally it is just one side if it is a physical connection problem.
Old Feb 7, 2005 | 07:19 AM
BudgetPlan1
Nope; tooled around a bit this weekend, no codes. Really just wondering what the C1248 was; doesn't seem to show up on many 2003+ code lists. Oh well, chalk it up to mechanical/electrical gremlins, I guess.
Old Feb 7, 2005 | 08:28 AM
bradfordjr's Avatar
bradfordjr
Sometimes this code can indicate low brake fluid.
Old Feb 7, 2005 | 10:12 AM
Richin Chicago
You didn't mention C1248 in your original post. It is low brake fluid.
Old Feb 7, 2005 | 10:48 AM
BudgetPlan1
Odd; brake fluid normal, right between min/max marks. Oh well...maybe i'll fill to max line.
thanks again...
To C1248 - DRP Disabled, what's DRP?
