What are the largest tire sizes I can install on a '04 Vert with Z06 Motorsport wheels (17x9.5 front, 18x10.5 rear) without interference? My Vert has been lowered on the stock bolts/bushings.
Do you have any traction control, ABS, or rubbing issues?
I'm running 295/45/18 on the back 9.5 stock rims, stock fronts, no ABS/Trac problems. But they do occure on some cars with more than 95% difference in tire height.
Yes, there is a slight rubbing problem. **** is jacked up about 3/4" above stock, still can raise more. Unbelievable traction, can't break 'em loose unless I dump the clutch.
