Check Engine Light Just Came On!!
I just checked the codes via:
http://www.stengel.net/diccodes.htm
All the codes that popped up ended in H??
Also the oil life on the display says 48%.
Thanks for any help!
Topher
Topher
Why don't you list the codes that popped up?
Are you sure none showed a suffix of "HC"?
Has the check engine light stayed on?
"The PCM monitors the fuel tank pressure sensor in order to determine the level of vacuum/pressure in the EVAP system. The PCM commands both the EVAP Purge Solenoid and the EVAP Vent Valve ON when the Conditions for Running the DTC are met in order to apply an engine vacuum to the EVAP system. The PCM commands the EVAP Purge Solenoid OFF once the system has reached a predetermined level of vacuum. This diagnostic tests for a vacuum in the EVAP system during a non-purge condition. This DTC sets if a vacuum continues to develop in the EVAP system after the EVAP purge solenoid has been commanded OFF."
