broken seat frame
Old Feb 6, 2005 | 01:59 AM
billiardcue's Avatar
billiardcue
Default broken seat frame
The passenger seat frame in my 04 seems to be broken on the right side of the seat. Car just turned 12000 miles and probably 10000 of that has been without a passenger.
Anyone with this same malady?
Old Feb 6, 2005 | 08:32 AM
Sixants's Avatar
Sixants
Haven't had the same problem on my 98 but this site may be able to help you out for less $.www.artscorvetteparts.com
Good luck!!
Old Feb 6, 2005 | 08:50 AM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
The driver's side bolster broke on mine. If you take the seat apart, they're made rather cheaply. I purchased a 2004 seat back (it's one piece fiberglass) and had it installed. I think it's a fairly common problem on some of the older Vettes.
Old Feb 6, 2005 | 09:55 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
when you say the passengers seat is broken, what exactly are you saying.. the lower frame at the frame rails, or the Back ?
with an 04 whatever it is, its covered under warranty.. Ive seen prototype C5 seat break under load test at one of the four linkage points in the frame rails, these leverage points are what controls the seat up and down. If this is the case then you need a new frame rail... its about a 700 dollar fix at the dealer, which is covered under warranty..
Further evidence of this breakage is you can manually lift the seat up and down from the broken corner..
If you further define what is broken maybe I can help...
Old Feb 6, 2005 | 10:24 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Dealer,,,,,,,warrenty,,,,,,,,,,save money and headaches,,,simple as that.
To broken seat frame
