which header gasket to use?
Old Feb 6, 2005 | 05:52 PM
donnyonee's Avatar
donnyonee
Default which header gasket to use?
which header gasket seems to be the best? i have a set of kooks and a set of oems.?
thanks,
donny
Old Feb 6, 2005 | 06:01 PM
purrvert's Avatar
purrvert
Heard bad things about the paper gaskets, re-used the stock metal gaskets, no problems.
Old Feb 6, 2005 | 06:43 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
The life expectancy of paper gaskets can be measured in minutes, use the stock metal gaskets
Old Feb 6, 2005 | 07:10 PM
Scubanme's Avatar
Scubanme
I've never had any luck with paper gaskets no matter what brand. I use the stock metal shim gaskets with no issues.
Old Feb 6, 2005 | 07:12 PM
Dave_Busch's Avatar
Dave_Busch
Stock is the best.
Old Feb 6, 2005 | 07:21 PM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
Yup, stock. I reused mine without any problems. ZERO leaks.
Old Feb 6, 2005 | 07:55 PM
vettenuts's Avatar
vettenuts
GM f-body gaskets. Same construction as the Vette, but the openings are round and fit the headers better and there is no AIR system opening. That is what I used on my QTP's.
Old Feb 6, 2005 | 11:09 PM
thetorch's Avatar
thetorch
I used these on my SuperMaxx's and haven't had a problem yet.
Old Feb 8, 2005 | 07:25 AM
Mr. Jones's Avatar
Mr. Jones
if you purchase a 2000 c5 gasket you will get the round port design. when gm changed the manifolds to cast they went to the oval port gasket.
To which header gasket to use?
