Coolant Smell Under Hood
Just a small question here. I often get a whiff of coolant smell sometimes from outside my car and mostly when I open the hood and look around after driving around. There are no coolant leaks under the car and my coolant resevoir level never goes down. The heater core doesn't smell like its leaking coolant either. So, my question is, do you guys get a small whiff of coolant under the hood too even if you have no leakage anywhere? I did just fix a small coolant leak from the water pump with half of a GM stop leak tablet, and my best guess is that I'm smelling the remains of the leakage on the block. Hopefully my head gasket isn't leaking or anything else big like that... Shouldn't be at 44k miles. Thanks for any insight you can offer!
