I-Forged fitment problems
Old Feb 6, 2005 | 08:16 PM
sprinter's Avatar
sprinter
Default I-Forged fitment problems
This is a follow up on a previous post regarding my I-Forged wheels not fitting with my 14" Baer Eradispeed brakes:
http://forums.corvetteforum.com/show....php?t=1007720
I ended up modifying the caliper so that the wheel would clear it by a couple of mm. Because I have 315/30 tires, they already poke out about 10mm so I didnt want any more from a spacer. I will give an update if I see any cracking or failure. Here are some pictures of the modified rear calipers:
Old Feb 6, 2005 | 08:37 PM
intel55's Avatar
intel55
hmm
what were the size of your rims again?
Old Feb 6, 2005 | 09:05 PM
sprinter's Avatar
sprinter
18x11" with 3" lip
Old Feb 6, 2005 | 09:27 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Glad to see you found a solution that you are happy with. Are you sure you left enough room for movement of the wheel and caliper?
VR
Old Feb 7, 2005 | 09:53 AM
sprinter's Avatar
sprinter
Originally Posted by vetterdstr
Glad to see you found a solution that you are happy with. Are you sure you left enough room for movement of the wheel and caliper? VR
As the brake pads wear, the caliper can only move inwards giving me more distance between the wheel. The brake pads have about 5000miles on them so I am hoping that when I buy new pads, I will still have clearance.
To I-Forged fitment problems
