Need a Doctor!!!!!!!!
Old Feb 7, 2005 | 12:28 PM
canadianguy's Avatar
canadianguy
Default Need a Doctor!!!!!!!!
I know this is not normal, but hoping someone can tell from pics exactly what is wrong and how bad is it? My car has been sitting since mid-November. It's obviously a leak, I'm guessing oil. Is this major work? It's an 04, should be covered, but if they fix it, I have heard they usually break something else...gm horror stories.
Old Feb 7, 2005 | 12:35 PM
Leo the Lion's Avatar
Leo the Lion
Cruise-In II Veteran
Try tighening the small bolts that hold the valve covers to the heads. These bolts sometimes vibrate loose and oil will weep out and down the head. But if you haven't driven this car for months then it could be something else. Good luck with this repair.
Leo
Old Feb 7, 2005 | 12:37 PM
Looks like either the valve cover gasket has gone bad or the valve cover itself needs to be tightened down. Should be a simple repair.
Old Feb 7, 2005 | 12:40 PM
canadianguy
Thanks guys for advice, glad to know it's not too bad, can someone use paint to show what bolts to tighten, I am pretty dumb when it comes to cars.
Old Feb 7, 2005 | 12:57 PM
canadianguy
Leo
Can anyone show, or describe which bolts to tighten, are they in the picture?
Old Feb 7, 2005 | 01:26 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Remove the rail covers to expose the valve cover bolts and tweak them a bit.
Do not overtighten as this can cause it to leak all that much more.
Old Feb 7, 2005 | 01:27 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
take it to the dealer..they break it they fix it..
Old Feb 7, 2005 | 01:46 PM
400hp's Avatar
400hp
You sure you didn't just spill some oil when you added? Because it would run down the filler neck and end up there. Or it's the valve covers. Remove your fuel rail cover, it just snaps off, and you will see about 8 bolts that hold the valve covers on. It will be obvious once you remove the plastic fuel rail cover.
Old Feb 7, 2005 | 01:51 PM
'99 Feather's Avatar
'99 Feather
Old Feb 7, 2005 | 01:57 PM
AR8007's Avatar
AR8007
Tighten your valve covers then clean up the old oil and drive it for a while and see if it returns, its better to run them periodicaly while in hibernation because of those types of problems.
Old Feb 7, 2005 | 01:59 PM
canadianguy
It has about 2500k, hasn't had an oil change yet. That's what worries me.
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Could it have been overfillled initially?
Old Feb 7, 2005 | 02:03 PM
canadianguy
Hopefully, how can sitting for a couple months cause this?
Old Feb 7, 2005 | 02:32 PM
mopac's Avatar
mopac
This is a CORVETTE It is an American Icon that was built to be driven She is an American beauty that does not like to be hidden away like an ugly duckling
Old Feb 7, 2005 | 02:37 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Yep......especially if its still under warranty. I agree it should be a simple fix, but if your not that comfortable in doing repairs, take it to the General....
Old Feb 7, 2005 | 02:42 PM
Patches's Avatar
Patches
Actually, you have to take the coil pack off as well to get to the valve cover bolts. You can see mine below which I painted red when I polished the covers. Do not overtighten! 106 in. lbs. That's 106 inch-pounds. The screws are held with aluminum threads.
With the coil packs still on.
Old Feb 7, 2005 | 03:49 PM
gairno's Avatar
gairno
Good pictures Patches. This should fix your problem.
FFIN90's Avatar
FFIN90
From: = From Toronto = 9/11/01 FDNY 343 Never Forget
CI 6-7-8-9-10 Veteran
St. Jude Donor '08-'09-'10-'11-'13-'14
Still under warranty, with above.
To Need a Doctor!!!!!!!!
